Fan clutch engage in the first 6 gears
Discussion in 'Ask An Owner Operator' started by Xenergiserx, Mar 20, 2023.
  1. Xenergiserx
    Xenergiserx Light Load Member
    107
    60
    Feb 2, 2021
    Hello I have an 2016 international prostar automatic. And the fan turns on every gear from 1 to 5 even when I’m not loaded. It’s that normal? And if not what can it be. ? Thanks l
  3. Spyro2112
    Spyro2112 Medium Load Member
    653
    453
    Mar 17, 2018
  4. Lazer
    Lazer Road Train Member
    1,852
    2,989
    Jan 22, 2017
    More than likely a setting in the ECM, I have used trucks that had a setting that kicked the engine fan on as soon as the pto was engaged, regardless of the engine temperature, and would stay on as long as the pto was engaged.
    Rideandrepair Thanks this.
  5. 201
    201 Road Train Member
    12,978
    26,759
    Apr 16, 2014
    high plains colorado
    I think turning on the a/c turns on the fan too. Might be running warm at idle, and takes a couple gears to cool off, not unusual. Garbage trucks with the pto running have the fan running, to cool the hydraulic oil. It's really annoying.
