Fan clutch or....???
Discussion in 'Ask An Owner Operator' started by Batman13, Aug 17, 2020.
  1. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    I have a 14 freightliner cascadia dd15...so last night I parked..and while sitting with the truck on for a lil...the ac stopped blowing cold..then I did a regen...sat with it for a while on..and I started to smell this smell inside the truck..clearly coming thro the vents...so I opened the hood and checked the engine and it was super hot!! Meaning way hotter then it clearly should be...so I turned off the truck..and had it off all night..this morning I turned the key on.. went to the fan to see if I could spin it and it spinned..also last night there was a hvac clutch fan spn0896 code..but now this morning there's no codes..anybody have any idea on what's the problem?
  3. AModelCat
    164,921
    What was the temperature on the coolant and oil? Opening the hood and going by feel isn't exactly an accurate indication of an overheat condition.
  4. Batman13
    110
    45
    May 20, 2020
    Sorry wrong code..code is hvac 025 spn 0876...clutch cir 01
  5. LDLWells
    LDLWells Heavy Load Member
    782
    1,219
    Jan 14, 2019
    If you run out all the air and then start the truck does the fan kick on?
    Batman13 Thanks this.
  6. Batman13
    110
    45
    May 20, 2020
    The coolant temp was 125..and the oil was 50..
  7. Batman13
    110
    45
    May 20, 2020
    Yes the fan turns on
  8. LDLWells
    782
    1,219
    Jan 14, 2019
    Does it stay on after the compressor cuts off?
  9. Batman13
    110
    45
    May 20, 2020
    I checked out the compressor cause I had a feeling it might be it..and yup it's the conpressor..
