fan clutch solenoid
Discussion in 'Volvo Forum' started by derdouf, Jun 20, 2015.
  1. derdouf
    derdouf Bobtail Member
    I have a 2005 volvo 660 vn, cummins powered, i would like to know where the fan clutch solenoid is located?a picture or a draw would be great. thanks
  3. asavage1576
    asavage1576 Light Load Member
    62
    36
    Mar 18, 2013
    Dallas,Tx
    Not totally sure on that model. Start up by the fan hub and find the 1/4 in air line going into it. Follow that airline and it will lead you to the solenoid
  4. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    If your truck is equipped with an ON/OFF air fan clutch the fan solonoid is located just above the LH front wheel (above the black plastic inner fender under the main cab harness) on a braket attached to the fire wall,the original solonoid is steel and most of the time the 1/4 plastic air tubing is green. The replacement solonoid is now full plastic black (if you buy it you will need also a little jumper harness to match the new connection style of the solonoid to the main cab harness.
    Ben
