Ok yall we havery a truck where the fan went into the radiator, thought the truck was put into too deep a hole. Radiator rpl, fan rpl and rpl all Springs and spring hangers as well as Motor mounts. Everything looked good then got a call it has happened again. We are at a loss and do not know what is causing this!!! Anyone have any experience with this?
Fan in radiator
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Covenantcrude, Mar 17, 2016.
Check the top radiator support bars that go to the fire wall. And check the rear engine and tranny mounts. Also measure the distance between the fan and the radiator.
Also, when you say you replaced the fan, do you mean the blade assembly or the fan hub assembly? -
We replaced the fan blade assembly. Once it is towed in AGAIN we will look at theach engine and transmission mounts. Did not rpl the hub. Just trying to get some ideas because we are at a loss.
Is the fan hub worn out? You might have to check with engine off, key on as most will exhaust the air and engage the fan clutch with key off, eliminating the bearing play.
First, what kind of truck?GrapeApe Thanks this.
This is an 02 Peterbilt 379
We didn't see a reason to change hub the first time. It gave no indication of this being the problem. However my husband did order one today. We will be changing it out as soon as the parts arrive.
I don't know if this is your issue, but it is very common. Aftermarket radiators come with a lower bracket that has offset holes that put the radiator 3/4-1" closer to the engine. The OEM bracket has holes centered (front to rear). I usually swap brackets, or if that's not an option drill new holes in the correct place.
The lower part of the radiator is pretty close to the frame brackets, but you should be able to get a finger in there. If it's tight, it's too close. Many times this works, but I've seen many fan kiss the radiator on the lower 1/2 of the fan. -
Years and years ago, a crazy farmer I know, went to work for the spring at the local co-op.
Everyone had trouble shifting this one truck, well, Crazy John marched up to it, spouting off about how you had to get your rpms real high to shift it.
Before he got out of the yard, he had the fan thru the radiator. -
Here's a picture of what I mean when I mentioned the wrong lower bracket. On the right is a new aftermarket radiator that I'm about to install in a 2001 379. On the left I'm holding the bracket that came off the old radiator that I will be putting on the new radiator. If you notice the location of the bolt holes, the new bracket would put the radiator closer to the fan, I'm not going to let than happen.
