Fan not working. 98 w900
Discussion in 'Kenworth Forum' started by irishluck09, Apr 24, 2022.
  1. irishluck09
    irishluck09 Light Load Member
    296
    183
    Nov 24, 2019
    I'm doing some maintence today after my first week in my new truck. My fan doesn't seem to come on automatically or with the switch
    First question is what temp should the fan kick on at?
    2nd question is I read somewhere that if that truck is off, that the fan should not move and if it does, then it's likely bad. Is this true? Because my fan clutch is free spinning with the truck off.
  3. Big Road Skateboard
    7,250
    41,328
    May 2, 2021
    Should kick on 210-218. Second question, that means nothing. Can you post a pic of the fan clutch?
    spsauerland Thanks this.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Try and unplug the power wire connector at the valve you will find at the end of air line coming from the fan, crank it up, see fan runs and if it does you may need to replace the air controll valve with the one that free wheels with air going to it and turns with no air goingto the fan?
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    98 could be air applied fan clutch, not air release.
    bjytech Thanks this.
  6. irishluck09
    296
    183
    Nov 24, 2019
    Alright so I took a little diagnosing. Like you said, disconnected the plug from air solenoid and turned on truck, fan is not engaged. Still free spins. I decided to check for air at the solenoid. There IS air coming into it. But I dont want to replace it not knowing if it's an applied air clutch or not. Im going to assume that it requires air to engage it hence looking at the fan clutch there is a gap between the 2 plates.
  7. irishluck09
    296
    183
    Nov 24, 2019
    So possibly a bad air solenoid? (And yes I took the air line off). The fan worked 3 weeks ago when I bought it testing it with the manual fan switch(which does not work either turning the fan on)
  8. irishluck09
    296
    183
    Nov 24, 2019
  9. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    It is a Horton HT fan clutch, air to engage fan clutch. Solenoid can be plumbed N.O. or N.C. Have to bench tested fan clutch actuator?
  10. irishluck09
    296
    183
    Nov 24, 2019
    Okay so my air valve is a normally close valve. I checked the valve and it's working. And I do have air coming in. So I guess at this piont I need to chase the ground and power to the ecm while checking for breaks.
  11. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Is it a Cat or Cummins?
