Fan override relay
Discussion in 'Peterbilt Forum' started by Cajuncowboy654, Oct 5, 2020.
  1. Cajuncowboy654
    Cajuncowboy654 Light Load Member
    138
    34
    Jun 4, 2019
    where would the fan override relay be in a 05 379?
    My fan won't always stay on with the override switch on. Tested the switch today and it seems fine so thinking tge relay may be going bad.
    The only relay in the fuse box i see in the diagram is called FAN LOW. Is that it?
  3. pushbroom
    pushbroom Road Train Member
    1,791
    7,403
    Sep 1, 2012
    Probably isnt one. Fan override switch will go right to the ecm to tell it to turn the fan on.
    Engine type?
    Washers on the dash or turn stalk?
    spsauerland Thanks this.
  4. Cajuncowboy654
    138
    34
    Jun 4, 2019
    Sorry its a cat bxs. Washer on the dash.
    I was yhunking relay because I can hea rather relay click, sometimes it will click on and off repeatedly.
    Other times if I flip the switch multiple times it will kick on, or if I push up on the switch it will catch. Thats why my original thought was the switch. But I couldn't get the switch to malfunction when I tested it today
  5. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    You might be hearing the air solenoid clicking which should be on the upper firewall close to the wiper motor area.
  6. Cajuncowboy654
    138
    34
    Jun 4, 2019
    Ok so any way to fix the unreliable over ride switch issue?
  7. pushbroom
    1,791
    7,403
    Sep 1, 2012
    It is most likely wiring from the switch to the ecm or intermittently faulty switch.
