Fan stuck (Cummins isx)
Discussion in 'Questions From New Drivers' started by Nuge31, Sep 20, 2017.
  1. Nuge31
    Nuge31 Light Load Member
    80
    54
    Sep 7, 2017
    I am getting ready to buy a truck with an isx in it. It has been sitting for about a year. The fan doesn't seem to want to stop running? Will these things get rust or debris around the clutch and stick? The guy selling it says it may free up on its own. Anyone have any thoughts.. thank you
  3. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    Is the fan hub getting air pressure? Depending on the model of the truck the solenoid for the fan may be located on the firewall. Unplug the air line coming out of it to the fan. Start the truck up and let the air pressure build up. At around 90 psi there should be air pressure coming out of the solenoid. If it does then the fan clutch is the issue. If not the solenoid is the issue. Clutches when they sit for a long time do have a tendency to stick just like brakes on some trucks.
  4. Nuge31
    80
    54
    Sep 7, 2017
  5. Nuge31
    80
    54
    Sep 7, 2017
    As the truck sits, the fan doesn't move, even without air pressure, which leads me to think it's clutch related, if I am not mistaken, without air the fan should spin freely. Does that sound right doesn't it free up even when the truck isn't running?
  6. Pepper24
    Pepper24 Road Train Member
    2,098
    1,640
    Dec 3, 2010
    I don't know about the Cummings on one of the cats I had you could hook air from an air hose direct to the fan hub turn the air on and off to see if the fan released was how he checked to see if it was the fan or solenoid .But I'm not a mechanic just watched the guy doing it
    Dave_in_AZ and baha Thank this.
  7. StrokerTSi
    StrokerTSi Medium Load Member
    532
    777
    Aug 28, 2016
    Usually the air pressure allows the fan to spin freely, no air pressure and the fan clutch is engaged.
    The Veteran, fargonaz and Dave_in_AZ Thank this.
  8. Dave_in_AZ
    427,107
    Mine sticks on occasion. Typically when I first start out. Sometimes won't happen for weeks. When it does, it will stick for 10 to 15 minutes.
    I also think this is some sort of corrosion issue in the fan clutch. My wrench tells me it probably is the fan clutch. He said it has like a fail safe to it, so that when it goes out it locks in, and will run constantly, so that it doesn't leave you walking.
    Please post what you find, if you find it before I do.
    fargonaz and Lepton1 Thank this.
  9. Sportster2000
    1,480
    886
    Jan 5, 2008
    Indiana
    The fail mode on the fan clutches are when there is no air to the they stay in the on position.
    The Veteran and Dave_in_AZ Thank this.
  10. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    My only experience with this (same engine by the way), is the fan will NOT free up. I ran about 2,500 miles and it never freed. Got about 4.8 mpg too during that time (according to the onboard computer)---truck was a rental, so I told them about it when I turned it in---then walked away, so I don't know what the 'fix' was.
    Dave_in_AZ Thanks this.
  11. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    My t800 fans comes on when I crank her, no air fan is engaged. Until it reaches about 80 on mine.
    So do like the guys said, pull air line after you build pressure and see if it is getting supply, if not it is engaged. After this step start trouble shooting relay, or temp sensor.
    Lepton1 and Dave_in_AZ Thank this.
