Fan Wiring Help
Discussion in 'Volvo Forum' started by nasriza, Aug 11, 2016.
  1. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Hey guys, so I have a head scratcher. This is the problem i have a 2001 Volvo d12 in my shop having issues with the a/c finally figured out what the problem is. A/C is shutting off because the APADS is seeing high side pressure being at 300 psi and fan is not coming on so it's shutting down a/c system all together. I know it's not high side switch already tried that, it's not APADS already tried that as well. I have it narrowed down to wiring between apads and VECU or ECU, the problem is I do not have access to any diagrams for that side, so I was hoping some of you could chime in if you had this kind of issue before or if you can get wiring diagrams.
    rollin coal and mp4694330 Thank this.
  3. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    174
    Oct 29, 2014
    Carlingford NB Canada
    oki i be with you and sing the Song " You are not alone"
    but my one is a 2012 780 :(
    i try to stop nose in and open the hood for better airflow ..
    i think about a manual fan switch
    mp4694330 Thanks this.
  4. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    this kind of problem I haven't seen in almost 10 years of working on volvo. other fan issues usually are very easy to figure out whats going on with your fan
    KB3MMX and mp4694330 Thank this.
  5. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    Correct me if I am wrong, but a 2001 won't have a vecu? That trigger wire for the fan should be direct from engine ecm to apads correct? I ran into this before years ago so I will check my notebook at work tomorrow and hit you back.
  6. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Im not so Sure if it does or doesnt usually when i get into wiring problems without a diagram i don't even try cuz it turns out to be a waste of time and i have no access to anything on this #### truck
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Please post serial number.
  8. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    On version 1 truck, only Volvo engine have VECU Cummins engine don't.
    Some quick test sir ,
    with engine running if you disconnect the Apad's plug harness the engine fan suppose to turn ON.
    If not, check in EECU (Vehicule Test Information) SUB system for ON -Off air fan Option OR VIscus Fan Option , viscus fan in that year don't have any interaction with the VECU.
    With the truck S/N check if the fan clutch installed match with what you see on the truck.
    In those system (Apad's Modul) wire 682 (by memory) is connected from the Apad's to the VECU, the VECU is requesting to the EECU via J-1939 to turn the fan ON under normal operation.
    About the Apad's system
    The high pressure switch is a 300 N.C. (Normally close) but inside of that switch there is a resistor of (2490 ohms by memory) but when the high side of the A/C system is below 300-325 psi you cannot read the internal resistance with a multimeter.
    The Apad's module send a 5 volts signal to low pressure and high pressure switch and the resistance inside of the switches give a residual voltage in the circuit when to switch come open.
    Hope it can help, let me know the result of your quick test please.
    Ben
  9. QUALITYTRUCK
    1,819
    1,783
    Jun 14, 2009
    romulus,mi
    I am sorry Nasriza. Checked all of my notes and could not find what I was seeking. If I recall (many years ago) problem was in ECM harness not far from ECM connector. Good luck.
    mp4694330 and nasriza Thank this.
  10. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    thanks for all the help guys
  11. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Hello
    Really Fan may be switched on by VECU comnand via J1939
    How VECU gets info to turn fan on? There are two ways - auxillary input and J1939 message from Climat unit.
    but these Behr units sometimes wond sending message and we used to run wire to VECU fan.
    Volvo terminal 3948725, pin PA19 (green connector).
