Fault code: MID 128:04, PID 131A
Discussion in 'International Forum' started by CraigInReston, Jan 22, 2026.
  1. CraigInReston
    CraigInReston Light Load Member
    138
    134
    Apr 6, 2017
    I recently started getting a CEL and active code for exhaust back pressure sensor. CEL will only appear under light engine load/low idle or during engine brake use. CEL disappears and fault code goes passive, shortly after increasing throttle/boost pressure.
    I’ve replaced the sensor and blew out both thermostat housing and manifold tube/pipe. Tested the voltage by back probing sensor while connected. 5volt supply is good. Grounding return tested at 0.2volt, which should be ok. But the signal wire fluctuates from 0.2-1.3volt, key-on, engine off.
    The wiring at the sensor connector is very loose and wires are spongy.
    I do have a minor exhaust leak coming from the flex pipe directly off the exhaust Y-pipe under the cab. Everything else is new.
    I’m stumped as to whether this is actually a low back pressure issue from the minor exhaust leak, or sensor/wiring problem.
    Any input would be appreciated.
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    Year make and model of the truck and engine are needed to help you better.
