Fault code
Discussion in 'Freightliner Forum' started by Sfrappier, Jul 12, 2018.
  1. Sfrappier
    Sfrappier Bobtail Member
    10
    Feb 18, 2017
    Shop says i have a fault code of 4634-18 and they have no idea what it is. Anyone ever get this code? I just had the one box replaced, 30 hours later i got a check engine light, went into shop and they said the intake manifold was leaking so they fixed that, now it has that code. Any ideas? Thanks in advance
  3. AModelCat
    164,773
    Must not be a very good shop because I just typed "4634-18 fault" in Google and the first hit was a troubleshooting procedure from Detroit.
    driverdriver Thanks this.
  4. Sfrappier
    10
    Feb 18, 2017
    Sadly it’s a Freightliner dealer and i agree they are not very good
  5. jayy408
    jayy408 Bobtail Member
    6
    Feb 22, 2018
    Since they replaced one box system I'm assuming they didn't put on new nox sensors I would connect it with a laptop run a parked Regen and keep an eye on inlet nox sensor and outlet nox sensor ppm and see if one of the number is jumping around all over the place or if it's too high or low in that case it would be a bad nox sensor
