feed back
Discussion in 'CB Radio Forum' started by mudkicker, May 15, 2011.
  1. mudkicker
    mudkicker Bobtail Member
    27
    walters,ok
    i had that feedback (static ) its fixed but i cant get out at all but my ears are good every things checked and good as far as coax , got a cobra 29 ltd with bluetooth , any suggestions?
  3. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Hummmm :biggrin_2556:
    When you push the PTT does the radio do anything ?
  4. Rat
    Rat Road Train Member
    What did you do to fix the "feedback"? Too me, feedback is something you get when you have the talkback turned on with too much mic gain or dynamic. You get a squeel over the speaker. Best fix for this is to turn off the talk back unless you have variable talkback then you can turn the talk back down a little. My connex doesn't have variable talkback so it is turned off all the time.
  5. mudkicker
    27
    walters,ok
    it was the power supply to the cb causing static feedback from the alternator , i fixed it and i got good ears but i cant get out , i had springs on ,i took them off and put them on again but i still cant get out , my coax looks fine , any suggestions?
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    What antenna are you running? If it's 5' or under, thats probably going to be your problem!
    When it comes to "CB Antenna's"...Taller the better....
