Few electrical problems on my 2006 western star 4900ex
Discussion in 'Western Star Forum' started by ihc4b, Dec 31, 2024.
  1. ihc4b
    ihc4b Light Load Member
    54
    19
    Dec 29, 2021
    First is my right turn trailer circuit is getting low voltage back to the lights. My trailer had a bad spot in the harness. Some wires got melted together. I think it damaged something in the trucks circuit. I get turn signals on the tractor correctly. On the trailer I get left turn , but right turn is very dim, only showing about 5 volts making it to the back. Is there some sort of replaceable flasher relay I can change. The truck has a signal Stat 900 turn signal switch.
    Second issue is a/c compressor won't disengage, unless I unplug it. Have also tried unplugging the high pressure switch. Also tried removing the high pressure switch and pluging it back in. I also believe this problem is causing my engine fan to stay on, as it won't disengage either.
  3. beastr123
    beastr123 Road Train Member
    2,989
    24,607
    Jan 2, 2014
    Moose Jaw SK CAN
    Is your heater set on defrost?
    The A/C is automatically on with defrost on some heating systems and that can include the fan being activated.
    The theory is to dehumidify the air blowing onto the windshield.
  4. ihc4b
    54
    19
    Dec 29, 2021
    Unfortunately it doesn't matter what position the switch is in. Although that is a point I had not considered. The vents do change with the switch. I was hoping someone else had solved this problem. I may have to start disconnecting all the wiring in the AC system one by one
  5. Lazer
    Lazer Road Train Member
    1,854
    2,993
    Jan 22, 2017
    With the ignition switch turned off, you should be able to view the ac compressor clutch, it should be disengaged.
  6. Ridgeline
    22,856
    126,627
    Let's start with what model truck and year?
    Crap, that was the first thing you wrote, sorry.
    I would recommend you get this - Amazon.com
    What is the voltage at the plug? 5 volts?
  7. Rideandrepair
    17,627
    57,046
    Aug 8, 2015
    Does it have a fan switch also? Located on dryer next to high/low pressure switch. Need to identify switches, find out exactly what they are. There’s bianary and sometimes trianary switches that have 3 functions all in one switch.
  8. ihc4b
    54
    19
    Dec 29, 2021
    I do have one of those. Although I have been a little disappointed with it. Those male prongs loosened up on mine resulting in me losing one of the prongs
  9. ihc4b
    54
    19
    Dec 29, 2021
    I do have a dash switch for the engine fan. The pressure switch is a 4 prong. It was recently replaced. No change. Unplugging it
  10. ihc4b
    54
    19
    Dec 29, 2021
    Unplugging it made no change. I plugged the old switch back into, but not screwed onto the drier. No change
