FH 12 piston problems
Discussion in 'Volvo Forum' started by phillipsgj, Mar 26, 2014.
  1. phillipsgj
    phillipsgj Bobtail Member
    I am having serious problem with a 1994 FH 12 with a D12A engine , it came into the workshop blowing water out the radator I removed the cylinder head and found a cracked liner and piston . I replaced all the liners , pistons and big end and main bearings inchassis after 1 day it died again this time on a diffrent pot . It has good oil pressure doesn't overheat but the pistons look like they aren't getting oil from the cooling jets they are not blocked and are pointing in the right direction . Has anybody have any ideas on where the issue is
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    clogged cooling nozzles. I use to clear thm every time I work on engine
    so local piston overheating makes so damage
  4. phillipsgj
    I removed all the cooling jets when I rebuilt the engine the first time and cleaned them they where not blocked , it seems like there is a relief valve or restriction in the oil galleries to to the coolers
    Thanks for your ideas
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    let me ask engine guy.
