Fifth Wheel Grease
Discussion in 'Questions From New Drivers' started by WITrucker87, Sep 17, 2013.
  1. WITrucker87
    WITrucker87 Bobtail Member
    39
    9
    Sep 9, 2012
    Kenosha, WI
    What do you use to grease a fifth wheel (is it specifically fifth wheel grease?) and do truck stops usually carry it?
  3. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    I want to just open these questions up! How about some wheel grease or barring grease? I don't think they sell it as "%th Wheel Drease but a general purpose grease, Is your 5th wheel binding up on you? Maybe it has to do with the Swift truck that is parked in 2 spaces that has your vision messed up!.
    baha Thanks this.
  4. tnscavenger
    tnscavenger Light Load Member
    259
    215
    Jul 21, 2011
    Maynardville, TN
    Yeah there is products sold as 5th wheel grease. Although, any heavy grease will do the trick. Also, splash a little diesel on the locking jaws in cold weather. Grease tends to get too thick in cold weather.
  5. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    i've been buying that lucas. for $11. you don't need much. and it lasts longer then the grease it gets from services.
  6. SemperFiServices
    SemperFiServices Medium Load Member
    379
    233
    Jan 29, 2013
    Indianapolis, IN
    I just use the same grease I use for the tractor.
  7. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    I like Lucas 5th wheel & slider lube. It doesn't "dry out" as fast as bearing grease and the dry spots are smaller when you get them.
    Be careful when storing it as the cap likes to pop off and spill crazy sticky goop all over the place. :tard: I don't trim the tip anymore and just unscrew the whole top and pour some out to apply it. it dosn't take much.
  8. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Don't get THAT stuff on your clothes..
    Try not to get it on your skin also..
  9. MysticHZ
    MysticHZ Road Train Member
    5,909
    5,738
    May 28, 2010
  10. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Lot Lizard Ooze
