Fifth wheel height
Discussion in 'Ask An Owner Operator' started by Adamali21, Aug 25, 2020.
  1. Adamali21
    Adamali21 Light Load Member
    278
    180
    Jul 24, 2018
    Hello everyone
    I recently bought a 2010 kenworth w900 it’s a heavy spec CAT-C15, the company that I currently lease on we only haul dry van, so am not trying to do any heavy hauling or tanker hauling. The company’s rules for fifth wheel height is 48” now the truck current fifth wheel height is 52” now how the hell can I get that fifth wheel height to drop. Wheel size are 315/80r22.5
    So has anyone had this problem before I am trying to get the fifth wheel height to 48” or less
  3. Tug Toy
    Tug Toy Road Train Member
    7,073
    73,989
    Jul 4, 2015
    Corn field
    Your drives are 315?
    I can see your steers being that but very odd choice for drives.
    There are different size stands that go under your 5th wheel on top of your slider. You can order different heights.
    But first check there is enough clearance before ordering and installing. Could be anything from frame height to tire size or 5th wheel? Or a combination of all the above?
    Roger McG, Brettj3876 and 650cat425 Thank this.
  4. Adamali21
    278
    180
    Jul 24, 2018
    Yeah thanks man so what’s the lowest tires I can put on
  5. Adamali21
    278
    180
    Jul 24, 2018
    so if my steers and drives are 315/80r22.5 what’s the smallest size can I put on
  6. Tug Toy
    7,073
    73,989
    Jul 4, 2015
    Corn field
    Are your drives duals? My guess is they are 9” wheels never seen 315 on drives. You’ll have to take a look. Should be stamped in the barrels?
    315 is one and a half inch taller than a low pro 22.5 (295 22.5) so that’s not going to gain you buy 3/4 of an inch.
  7. beastr123
    beastr123 Road Train Member
    2,952
    24,213
    Jan 2, 2014
    Moose Jaw SK CAN
    Changing to 275/80R22.5 tires will drop your fifth wheel height by 1 inch.
    Your fifth wheel may be on a high rise mount, and a low rise fifth may drop your total height by a few inches.
    Trucks can be built for different applications and you seem to have bought a truck built for different purpose than what you want to do.
    You can adapt it but it may be expensive.
  8. Adamali21
    278
    180
    Jul 24, 2018
    I need to drop 4 inches, what about fifth wheel risers, i was reading about those as well
  9. Adamali21
    278
    180
    Jul 24, 2018
    I was doing research could changing the fifth wheel risers help me or do I have to change the whole fifth wheel
  10. Cat sdp
    Cat sdp . .
    21,316
    76,312
    Apr 8, 2012
    Orion's Belt
    You can reuse the plate . But it’s gotta come off to get to the risers.....
    Adamali21 Thanks this.
  11. Adamali21
    278
    180
    Jul 24, 2018
    Man I just hope changing the tires and fifth wheel components get me in the correct height for dry van.
