fifth wheel lube plate?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cumminsISB, Jul 30, 2013.
  1. cumminsISB
    cumminsISB Light Load Member
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    I know you can buy the big ole disk with the metal retaining ring to install, but what I am looking for is one to bolt or weld to the top of my existing top plate. I have seen them before, but for the life of me I cannot find them using the google machine on the internet! Can someone point me in the right direction? Thanks!!
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    I believe what ure looking for is the new holland 5th wheels come with it but ive never had to order one so i dont know where u can get it from
  4. cumminsISB
    176
    10
    Feb 5, 2011
    D'Lo, Ms
    yeah I am looking for one like the new no lube fifth wheels come with but my jost fifth wheel can be rebuilt for $200 and I like it. Just tired of the mess with grease and have always had a problem with getting one of the big ole disk installed right.
  5. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    You can get the two separate pieces of teflon and just bolt them on you dont have to get one disk it will work the same way as the trailer will just ride on the two separate halves its kind off out of the box thinking but just an idea i dont think they make what youre looking for jost fifth wheels
  6. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    http://linersystems.com/final-lube.php I bought and installed this type and has held up for 2 years so far. The only thing you need to know is your kingpin depth so they can sell you the right plate.
    2bit, cetanediesel and HISPEED428 Thank this.
  7. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
    Is this attached to the king pin plate?
  8. pullingtrucker
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    Yep it is attached with counter sunk screws around the perimeter. All you have to supply is the tools and time for install. I installed mine in about a hour.
  9. DieselDummy
    DieselDummy Light Load Member
    173
    62
    Apr 1, 2012
    Willet,NY
  10. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    This had worked very well for me:
    Place the disc and ring into position, take a generic king ping lock and place it on the pin. Then jack it into place with a bottle or floor jack using appropriate dunage.
  11. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    Leave the metal lock ring taped to the disc. Put an oxygen or acetylene bottle cap under the disc. Drive it on with a sledge hammer. Requires a little coordination but not too bad.
