Fifth wheel placement.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by michaeljcheaney, Oct 2, 2017.
  1. michaeljcheaney
    michaeljcheaney Bobtail Member
    27
    18
    Aug 21, 2009
    Wisconsin
    Right now I am loading about 46k of liquid fertilizer, and I am certain it will put me over on my steers and drives.
    Will sliding the 5th wheel all the way to the back, help me weight wise? (Right now, its sitting right between the drives)
  3. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    No. It would only move weight from drives to steers or vice versa. If you will be over on both it will not help.
  4. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    what state. and what state u traveling threw
  5. 77fib77
    77fib77 Road Train Member
    11,796
    78,164
    Jul 7, 2010
    St Louis
    I have the king pin forward of the center of the drive axles.
  6. RockinChair
    RockinChair Road Train Member
    5,421
    14,647
    Feb 19, 2012
    Lubbock, TX & thereabouts
    This.
    If you need to move weight from the drives to the tandems, you can try to adjust the leveling valves on your air suspension. Raise the ride height on the drives, lower it on the tandems, or both.
    If this is a recurring problem, consider having your fifth wheel raised. Also, you can install taller drive tires, or shorter trailer tires.
    77fib77 Thanks this.
  7. AtticusRoad
    AtticusRoad Medium Load Member
    301
    688
    Oct 30, 2016
    Indiana
  8. Grouch
    Grouch Road Train Member
    2,131
    4,424
    Feb 3, 2009
    Between here and eternity
    46K putting you over?? Your trailer or tractor must be pretty heavy. I can scale 49700 of milk with 150 gals of fuel in a 2009 Columbia sleeper. I run my 5th wheel all the way up.
  9. MACK E-6
    50,215
    240,300
    Without knowing what your tare weight is, sliding your fifth wheel back will only compound the problem. If the drives are over, move forward.
  10. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,650
    Aug 28, 2009
    Airlie Beach QLd
    Only way to find out for sure is put it over the scales then you'll know which way to move it, i just know when you slide the axles back you transfer all your weight forward so does it work the same way with the 5 wheel? If so you shift more weight to your steers. i guess loading a tanker you don't have the luxury of being able to move your back axles the other way would be to fill less weight in your front end of the tanker by closing the baffle just remember to reopen it when your unloading.
  11. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    I agree, I can pull a milk wagon the same wait and am legal, and they have no baffles.
    All tires on my set up are 24.5, plus the 5th wheel sits about 1 inch high which pretty much levels out set-up.
    Placement of kingpin on these wagon is 1 to 2 inches front of my front driver.
    If I pull baffled trailer with crude or diesel I have to be careful and not load first compartment more then the others,, crude not so much open baffles.
    Lots of factors, APU, pump, fuel tank position, etc.
