Fifth wheel would not release
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Mar 2, 2021.
  1. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    When I came in last night I could not get the fifth wheel release. No matter how I positioned the tractor backing up to give me slack to release it the Jaws were just locked in.
    So I bopped the adjusting bolt with a hammer and right away it released.
    Does this mean now it is time for me to replace the fifth wheel?
  3. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    Did you have the air bags dumped?
  4. Rideandrepair
    17,576
    56,939
    Aug 8, 2015
    Have to remember that trick. When all else fails, BFH !
    Bean Jr., Dino soar and 062 Thank this.
  5. Capacity
    Capacity Road Train Member
    1,499
    3,119
    Jul 28, 2019
    Neenah Wi
    Ah great advice , never new about the washer deal.
    I never touched my fifth wheel except to clean it up with a putty knife and leave the adjustment or rebuild to the pros , to much devastation could happen if that wagon comes off.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I had a truck with a Fontaine fifth wheel. If the truck wasn’t on flat ground it was difficult to operate both hooking up and releasing.
    Dave_in_AZ and Bean Jr. Thank this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,778
    9,212
    Jul 12, 2017
    Did you adjust recently ? Is it maybe just too tight? . Holland?
    Try cranking the adjuster down a half turn and see if it sticks again.
    Dave_in_AZ Thanks this.
  8. Dino soar
    4,815
    27,071
    Dec 8, 2017
    I adjusted it once maybe 6 months ago. I've never had one problem releasing it in all this time. I was backed into the same spot that I always dropped the trailer there was nothing unusual about the terrain or anything else.
    So the half a turn would be a clockwise turn on the adjuster Bolt?
    Yes fw35 Holland.
  9. 062
    062 Road Train Member
    6,345
    34,003
    Oct 20, 2013
    Have you been running where they put down a lot of sand? I’d trip the jaws and check for debris.
  10. 201
    201 Road Train Member
    12,820
    26,398
    Apr 16, 2014
    high plains colorado
    How cold was it out?
  11. Dino soar
    4,815
    27,071
    Dec 8, 2017
    No I normally don't but I tried it Every Witch Way dumped up back forth whatever. No bueno
