Filter on FLD 120 axle?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wr2001, Jan 11, 2017.
  1. wr2001
    wr2001 Light Load Member
    88
    18
    Apr 27, 2012
    Las Vegas
    i noticed a filter on the axle (1st axle, not the drive axle)of my FLD 120. what is the filter for? its small like the size of a car oil filter. picture points to where filter is located. sorry i dont have a pic of it (not my truck).
  3. Blackshack46
    Blackshack46 Road Train Member
    Cant help you with the picture. Maybe if you send me the keys and location of the truck.
    Its 1 of a thousands. But i like the look.
  4. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    It's a pumper rear end, there is a pump in that rear carrier. the filter keeps, well the filter does what a filter does to prevent pump failure
  5. wr2001
    88
    18
    Apr 27, 2012
    Las Vegas
    i
    Is it just for that particular axle or is it part of the entire rear end (both axles)?
  6. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    it filters the oil in that axle
    Roger McG Thanks this.
  7. AModelCat
    161,603
    Its just an oil filter for the front drive axle. Nothing special. Change it out once or twice a year.
  8. passingthru69
    Yep got one on mine. Change it out every year when you change out your rear end oil.
  9. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    I'm confused, you say not the drive axle, but have a picture pointing to a drive axle? If your drive has a filter, it has a pump in it, which was an option for better lube. You usually see them on trucks set up to run heavy, off-road. or other severe duty applications, but I've seen them on regular over the road trucks.
  10. wr2001
    88
    18
    Apr 27, 2012
    Las Vegas
    Finally got around to grabbing pics of filter...just wanted to double check and confirm the purpose of the filter...left side first pic top view second pic...
  11. AModelCat
    161,603
    Yeah its just a filter for the forward drive axle. Should change it out every year at least.
    wr2001 Thanks this.
