Finally got my Cummins pulled down
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AUSSIE DAVE, May 22, 2010.
  1. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Hi all, finally got my Cummins M11 pulled down ready to start on the inframe rebuild, boy did I have fun trying to make a tool to pull the piston sleeves out, but with persistence and several modifications to the tool, I got all 6 sleeves out YIPPY. So next will be go and buy the kit, clean the block (remove remaining gaskets and grease/sludge) then start by installing new main bearings, and move onto new piston sleeves, pistons etc. I feel much better now that I have finished the tear down. :biggrin_2559::biggrin_2559::biggrin_2559::biggrin_2559:
    kickin chicken Thanks this.
  3. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    kepp us updated i have a m11 in my dump:biggrin_25514:
  4. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    excellent.. post pics if you get them
  5. Rnz520
    Rnz520 Bobtail Member
    30
    8
    May 4, 2010
    Fredericksburg, VA, USA
    yes, m11s are very simple engines to work on, you should not have a problem doing one.
  6. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    No worries mate, i will try and keep u updated, going to finish cleaning engine this weekend and then start on re-assembly the following weekend. ( i work monday to friday so saturday and sunday are for working on my truck)
  7. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Thanks, you got any tips, like what would u use on the sleeve seals, 15/40 or liquid soap?? and on the the bore and pistons and rings 15/40 or 2 stroke oil??
  8. Rnz520
    30
    8
    May 4, 2010
    for all bearings and moving surfaces we use Lubriplate 105 engine assembly grease.
    I dont know if you can get that where you are at but its a great lubricant and keeps wear to almost none during initial cranking and startup before oil pressure is built up.
    15/40 is a fail safe way to go about it in my opinion, its what I would use.
    Go and take as long as possible cleaning everything, if you have a hot parts washer that uses soap try not to use it on internal engine parts, and if you do reclean them with Varsol or another parts washing solution, the problem with the hot soal is that it leaves soap stains, and that causes hot spots and increased friction in internal engine parts.
    I leave this part to your discretion since you have pulled it apart and know the condition and look of the crank, but I always, always, always check my bearing clearances on mains and rods, a lot of the guys at work just torque them to spec and thats it unless it had a bearing failure. The bigger engines are more tolerant to a larger/smaller gap when it comes to that, but I do not see the damage in checking the clearances and making sure they are to spec, it will cost 4 dollars (US) in Plastigauge and maybe an hour or two extra of your time if you do it slowly.
    It is peace of mind, and it being your own engine is more of an incentive to do it. Just make sure you clean the residue as well as you can before you put it together for real.
    AUSSIE DAVE Thanks this.
  9. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Plastigauge I take it that this is for checking as per checking piston to valve clearances (put on piston rotate engine etc, etc), but you use it to check bearing to crankshaft instead. Also thanks for the other info very helpfull, P.s I will be useing lucas oil stabiliser as assembly lube on bearings. once again, thanks mate :biggrin_255:
  10. AUSSIE DAVE
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    Hi all this is my Kenworth T401 that I am doing the Inframe on, as well as other work, getting her ready to start subcontracting some time this year. it is bogee drive, 18 speed road ranger box, Cummins M11 rated at 400HP, and you can see the other features in the pic.
    [​IMG]">[​IMG][​IMG]
