Finding Fuel in my Oil
Discussion in 'International Forum' started by MrMgeezy, Sep 7, 2016.
  1. mc8541ss
    mc8541ss Road Train Member
    1,462
    2,016
    Sep 22, 2007
    Lower Alabama
    MrMgeezy Thanks this.
  3. 6-pack
    6-pack Bobtail Member
    34
    29
    Aug 30, 2016
    Terrell, TX
    Replaced injector o rings and back to rolling good
  4. MrMgeezy
    MrMgeezy Bobtail Member
    12
    5
    Sep 7, 2016
    Mannn..You were lucky the O Rings wasnt no more than $50 maybe plus labor.I replaced all six on mines & still fuel getting in thier somewere.Ill find it though.Hey thanks for your insite..
    6-pack Thanks this.
  5. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Here's what the book shows. This is for an N14, not a ISX, but may give you some ideas.
    Heavyd Thanks this.
  6. MrMgeezy
    12
    5
    Sep 7, 2016
    Aw man that info is a Blessing im going to print it out & see if i can get some insight on it.I think both Engines are pretty much same in most cases.
  7. Heavyd
    Heavyd Road Train Member
    7,839
    6,295
    Feb 4, 2009
    Usually injector cups are too low to get fuel into the oil. Injector cups have coolant flowing around them, so usually you can safely blame them for fuel in the coolant.
  8. MrMgeezy
    12
    5
    Sep 7, 2016
    :cool:
    Hey ShooterK2 I have some good news on my end.I had my truck checked again by another Tec.The First thing he checked was the Fuel Return Line that you mentioned,which was not clogged up.Then he ran another dye test,which i already had done & didnt find anything.The only thing he did different from the first tech was,First he got a suction hose,sucked all the oil out that sits in the top of the engine.Cleaned it up as good as he could.He said that with so much being in there (the Oil) with the engine running it could possible dilute the dye if the leak wasnt that bad.Anyway after cleaned up.He poured the whole content into the long Fuel filter.(which the first tech only used Half,possibly not enough)Then he took the Valve cover off.as soon as i crunk it up.Here comes the dye .LUCKY INJECTOR # 3 Lol.It was so visible that you didnt even need the black light.As the oil begine to flow it started to dilute it a bit as it mixed.Hope this help some one I thank you Guys for your advise. Im going to get this sucker smoking again......:cool:
  9. ShooterK2
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Awesome! Glad you found it.
