Fire Extinguishers
Discussion in 'Trucking Industry Regulations' started by nj diesel, Aug 28, 2013.
  1. nj diesel
    nj diesel Bobtail Member
    42
    10
    Apr 22, 2012
    What are the DOT regulations regarding on-board fire extinguishers as far as the date on the tag or just having a tag? Obviously I know it must have a good pressure reading on the gauge, but anything else to be aware of?
    mp4694330 Thanks this.
  3. mp4694330
    mp4694330 Road Train Member
    1,530
    1,461
    Aug 30, 2010
    Chicagoland
    Great question, wonder myself???
  4. morr2fab
    morr2fab Medium Load Member
    338
    110
    Oct 3, 2012
    I believe it needs to be A-B-C type or multi purpose dry chemical.
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    There was one time I took a set of welding tanks to get filled and the guy told me he couldn't fill them because the inspection testing date had expired. It has to be done every 10 years according to some ANSI standard (not DOT). I ended up paying to swap for good tanks. I don't know if that applies to fire extinguishers or not? There would be a date stamped on the tank somewhere if they were included. I was under the impression inspections applied to all portable tanks. I never looked at one that close. :)
    mp4694330 and Scalemaster Thank this.
  6. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    Cylinders for HM like welding gasses are required by DOT to be re-tested at different intervals, depending on the specification of the cylinder.
    Fire extinguishers are cylinders, but i am not sure on test and re-test requirements for them.
    A portable tank is a different packaging altogether.
    mp4694330 and CondoCruiser Thank this.
  7. nj diesel
    42
    10
    Apr 22, 2012
    That really was my question. Is the age of the extinguisher a factor in any way for DOT Troopers as long as it has good charge? Either the bottle itself or the date on the tag.
  8. Scalemaster
    808
    1,717
    Mar 13, 2011
    Midwest
    I don't see in the regs anything about dates being expired. Just an indicator that it is charged.
