First day behind the wheel!!
Discussion in 'Trucking Schools and CDL Training Forum' started by Michelle33, Mar 7, 2024.
  1. Michelle33
    Michelle33 Light Load Member
    61
    109
    Feb 19, 2024
    West Texas
    Hi everyone :D Here's an update on how my CDL school is going- week 2.
    I received my official CLP yesterday and I started driving today!! Im just super excited!! However, I'm quite terrible at double clutching. I thought it would be similar to driving a 5 speed car manual BUT it is not. So I'm feeling a bit discouraged..
    I've done pretty well with learning my pre-trip, passing all my tests etc- so this double clutching has me feeling pretty down. I recorded some videos of my instructors shifting, so I'm planning on going over it and practicing with a make-shift setup at my house. I'm hoping tomorrow will be better. :) We've also had some different recruiters come through. RE West, TMC, Swift & Liberty. Anyways, just wanted to give an update-
    The_vett, austinmike, Lonesome and 5 others Thank this.
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,015
    2,086
    Dec 15, 2021
    It takes some practice.Get your rpms up high enough before you start to shift.After awhile you'll be shifting easily and not even thinking about it.
  4. lual
    lual Road Train Member
    5,342
    9,762
    Oct 22, 2020
    SW Georgia
    Don't let the double-clutching discourage you.
    You will later find that most fleets now have pretty much gone to (or are in the process of) automatic transmission-equipped tractors.
    Some exceptions to that: the off-road fleets -- loggers, & the oil field crowd; & also, heavy haul/oversize/overweight.
    -- L
    Flat Earth Trucker and Michelle33 Thank this.
  5. Chinatown
    Chinatown Road Train Member
    77,789
    184,707
    Aug 28, 2011
    Henderson, NV & Orient
    Where is Liberty out of; headquartered?
  6. Michelle33
    61
    109
    Feb 19, 2024
    West Texas
    Liberty Energy is located out of Midland County, Texas. They are opening up a new location in Cibolo?, Tx. They have sites all over though- LA, CO, ND, WY. But the job they were offering to us was more along the lines of heavy labor- There wasn't much actual driving- other than the 2 hrs or so each day of hauling to the job site.
    Chinatown and Flat Earth Trucker Thank this.
  7. TexasRiverRat
    TexasRiverRat Light Load Member
    291
    1,912
    Sep 4, 2021
    I've only had my license for about a year and a half, so I can still remember how excited I was to start driving and how embarrassed/frustrated I'd get when I'd miss a gear or grind one.
    We all started somewhere, so don't beat yourself up over the first day of driving. The only way to improve is through practice, and eventually it'll become second nature.
    Speedy356 and Michelle33 Thank this.
  8. lual
    5,342
    9,762
    Oct 22, 2020
    SW Georgia
    Hang on to those recruiter business cards & any other handouts.
    In the current CDL job market for rookies -- those may later be you best hope.
    -- L
    Michelle33 Thanks this.
  9. 201
    201 Road Train Member
    12,791
    26,322
    Apr 16, 2014
    high plains colorado
    Wonderful,, now get to work,,,kidding, you'll be fine. Most will agree, the "double clutch" thing is a waste of time. I don't want to confuse you, but you should only need the clutch to start and stop. After a while, you'll see, when you let up on the throttle, and pull the shifter out of gear, there is a "sweet spot" for the next gear, and no clutch is needed. If you gently "ride" the gear with the lever, you'll feel when the gears will mesh. Typically, new drivers tend to over-rev the motor. Remember, in a diesel, the space between gears may only be 4-500rpms, and 2-3000rpms in a car. Usually, just a tap of the throttle is all that's needed. Now, practice that backing, you'll be fine.
  10. mitrucker
    mitrucker Road Train Member
    5,494
    10,354
    Dec 15, 2010
    Lapeer, MI
    That picture screams RUN AWAY!!!!!!
  11. Lonesome
    Lonesome Mr. Sarcasm
    11,714
    24,440
    Dec 15, 2007
    Northern Indiana
    Good luck to ya!
