First dot level one inspection!
Discussion in 'Questions From New Drivers' started by SAMMY6969, Mar 4, 2012.
  1. SAMMY6969
    SAMMY6969 Medium Load Member
    371
    121
    Nov 12, 2011
    MY QUESTION..THEVOTHER DAY IN WALTON KY..71/N..GOT PULLWD IN TO SCALE HOUSE..15 NEW STATE TROOPERS,TRAINING..DECIDED TO GIVE ME A 100% LOOK WITH DRUG SCREEN..I DID FINE..ALL MY STUFF WAS 100% 3 HRS LATER ..MY TRAILER HAD A BLOWN WHEEL SEAL WHICH NEEDED REPLACED ALONG WITH BRAKE PADS ,BEFOR TRUCK COULD BE MOVED...PLUS NO ABS ON TRAILER...OK 9 HRS LATER ITS FIXED IM SKATE BOARDING DOWN THE ROAD....I RECEVED NO TICKETS..BUT HOW DOES TRAILER WRITE UPS AFECT MY drivers license ...??(FLATBEDER)
  3. snowblind
    snowblind Heavy Load Member
    775
    636
    Jan 29, 2011
    conover nc
  4. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    as far as i understand the CSA, anything that can be fixed on the spot by you or roadside (bad tire, air leak, wheel seal, etc) will not get you a ticket. and about the ABS.........from what i have been told they can not put you OOS for a simple ABS light. the light indicates that the antilock feature does not work.
    is there anything at all on the form they gave you to send in to your company? if not, then you have nothing to worry about.
    and a drug screen at a scalehouse? do you have proof of this? that is a new one on me. wait for one of the other members who is more familiar on the FMSCA chime in on that one. i would think that you just had some rights violated.
  5. 123456
    123456 Road Train Member
    10,555
    5,748
    Oct 22, 2010
    32179
    When you were issued a cdl,
    you lost some of your, so called, Rights !!!!
    :biggrin_25513:
    AdamT2k Thanks this.
  6. SAMMY6969
    371
    121
    Nov 12, 2011
    THEY DID NOT PUT ME OUT OF service ,FOR THE ABS..JUST WROTE THAT DOWN...THEY PUT ME OUT OF SERVICE FOR WHEEL SEAL,ALSO DEMANDED BRAKE PADS TO BE REPLACED NOT CLEANED....THE SHEET THEY GAVE ME SAID ..POWER STERING LEAK,ABS LIGHT,BLOWN SEAL, BRAKE PADS,,,THATS IT...SO NONE OF THIS WILL BE PUT ON MY DL???? (RECORD). ALL MY STUF WAS 100% SAD THING IS I WROTE TRAILER UP 10 DAYS PRIOR TO THIS..DROPE TRAILER..ONLY TO PICK UP SAME TRAILER THAT WAS NOT REPAIRED....WTF....I JUST NEED TO KNOW IF THIS INSPECTION AFFECTS ME IN ANY WAY..
  7. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    DOT can give drug tests.There's is suppose to be a drug test kit in your trk and don't leave the terminal without one.I have never had a drug test done on the road.Don't think officers give drug test without probable cause but in this case 15 officers were getting trained so maybe they gave him one as part of the training process and the officers picked him out to be their guinnea pig,lol
  8. oldmack
    oldmack Light Load Member
    52
    42
    Apr 9, 2011
    philadelphia, pa
    I have never heard of being required to carry a drug test kit.
    Motownfire Thanks this.
  9. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    My question is so why did u leave the yard with the same trailer without it getting fixed.You're just as much to blame as the company.Yes that inspection is going to affect you big time.You now have some serious points on your CSA.I would go to the FMCSA website and see how many points each of violations are and start doing your pretrip and do not leave the yard till all that stuff is fixed.CSA and the law ain't playing.Carriers now look at CSA scores from drivers before they get hired.
    Tazz Thanks this.
  10. Everett
    Everett Crusty Shorts, What???
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    i just want too know , too avoid this next time, were did you pre trip went as taught to you, out the window, i see this as i would gave you a ticket myself, for you didnt do a proper pre trip, if you left the yard , knowing the trl is not fixed, then its your fault, i would never leave the yard , if there a problem with the trl, ever wacth u tube , some scary movies there , as the trl tadems come flying off , going down the interstate, they might save someone life by shuting you down, btw on abs light, if your tractor not setup for abs , the light wont come on ether way.
  11. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    You have'nt?Who do u drive for?Reason u have to have a drug kit on board is say you got into an accident and officers think you may be at fault,they're going to make you take a drug test right on the spot and they're not going to furnish you with a drug kit.
