First Major Repair!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by reelheavy, Jan 28, 2020.
  1. reelheavy
    reelheavy Light Load Member
    94
    55
    Mar 15, 2017
    Maryland
    Attached is a quote from the freightliner dealer just bought the truck in November ony put 10k miles on it and first major repair.
    jsnell Thanks this.
  3. CaptainDaveG
    CaptainDaveG Road Train Member
    1,478
    2,359
    Jul 31, 2014
    Fremont Wi
    I’d have them clean out the system. See if it holds air then before removing the Trans.
    Be Safe Out There
    Captain Dave
  4. wichris
    wichris Road Train Member
    4,498
    9,255
    Jan 17, 2011
    Remember when floors came out of the truck and you could work on a trans without removing it?
    Badmon, x1Heavy, jsnell and 1 other person Thank this.
  5. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    is this 13 speed eaton fuller ? and what mileage you have?
  6. reelheavy
    94
    55
    Mar 15, 2017
    Maryland
    10 speed just hit 600k miles
    mhyn Thanks this.
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Tsk. Its a very nice description though. Bill is typical almost 6 grand. And still things to chase.
  8. reelheavy
    94
    55
    Mar 15, 2017
    Maryland
    Yeah when it's cold out it take the truck forever to build air. And it is always stuck on the high side of the transmission. No matter where you have the range selector. But if you have it on the high side you can hear air coming from the shifter itself. But if you drive a while she will finally go to the low side air will start to build normally and shoot off. And the truck drives fine. I changed the air dryer cartridge myself cleaned it real good. It seemed to be the original one the truck was produced with. I drain my tanks daily. I see a small amount of mist when I first open the valves and then that is it.
    The thing that is throwing me is the fact that they are saying it is water on the top plate of the transmission that is freezing But if it was water on the top plate wouldn't water be in the transmission itself?
    x1Heavy Thanks this.
  9. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    If I remember my temperatures, a transmission and axles operating at 210 or higher when working hard would boil that water away in a hurry.
  10. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    The top plate just houses the air valves for range selection and such. Generally they can just take that off without removing the trans.
    Looks like the previous owner didn't drain the air system that often. If they find rust, have then check the DEF dossing valve as well.
    flood and Dave_in_AZ Thank this.
  11. Dave_in_AZ
    424,525
    WINNER!!!!!
    Who had the truck for the first 600K. That counts for a lot.
    mhyn Thanks this.
