Fitting a headache rack behind a 379
Discussion in 'Flatbed Trucking Forum' started by T-800, Mar 1, 2018.
  1. T-800
    T-800 Light Load Member
    98
    45
    Sep 20, 2014
    Frankfort, IN
    ive got a 379 with 63” standup and need a headache rack for chains/binders. I’m wanting a cabinet but am not sure if I will hit with a trailer. Whoever put my 5th wheel mount on must’ve been drunk because with the plate slid all the way back it sits just in front of center. Anyone had any experience with this? I’m thinking I will have to get a shorter sleeper to fit the cabinet but 48” bunks are pricey because they apparently “look cool”
    Oxbow Thanks this.
  3. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    Also on a side note, which is easier; putting a flat top cap on an ultra cab or the sleeper? Don’t need the wind resistance with what I’m doing
  4. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    Do you have a big front end?
    Oxbow Thanks this.
  5. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    I run my 5th wheel up that far to get decent weight on my steer axle all the time. Anythime longer than 244 shouldn't have any problems fitting a headache rack in there. Save your money on the bunk question. Its a big job either way and not worth it imo
    Oxbow and stwik Thank this.
  6. easytopleez33
    easytopleez33 Light Load Member
    251
    325
    Jan 6, 2015
    What's the Pin setting on your trailer?
    Not knowing what kind of wheel base your working with, your question is hard to answer.
    Transforming the sleeper is a costly endeavor, and not worth it in the long run.
  7. TripleSix
    133,483
    You have more options than you listed.
    First however, what's your wheelbase? If you have the extended hood, you want a minimum of about 265wb. If you don't have the wheelbase for an enclosed headache rack, you can add boxes to the trailer OR install a header board with a built in chain rack. I believe CRST Mallone runs those types of trailers.
    And if you could, can you post a pic of your truck with the 5th wheel all the way back?
    Opendeck Thanks this.
  8. Long FLD
    Long FLD Road Train Member
    12,913
    54,166
    Mar 4, 2015
    What’s the wb on your truck? Plenty of Canadian guys run cabinets with 244” wb. Moving your 5th wheel plate or carrying gear on your trailer would be cheaper options than a smaller bunk.
  9. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    Well it’s a short hood, but has I believe a 260 base. I currently carry everything on my trailer but am looking to add a lowboy and want all my chains with me if I switch trailers. It wouldn’t matter too much but I’d like to still be able to pull a van if needed. That’s where my issue is
  10. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    And I forgot to mention I have to replace the sleeper regardless. I wrecked my truck in December and one of the rear mounts ripped out of the sleeper and also dented one side up
  11. cke
    cke Road Train Member
    6,176
    76,057
    Aug 4, 2013
    Colfax Wi
    I have a short hood 260 wheel base 379 with a 63 inch sleeper. I got almost 6 feet between the front of my trailer and the rear of the sleeper. I’m pretty sure you can fit a enclosed headache rack in there
    spyder7723, Oxbow, Ruthless and 2 others Thank this.
  12. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    5924F595-F3A2-45EA-A880-84EB93E22FC1.jpeg That’s the best picture I have of the combo
    cke Thanks this.
