After fixing both rear differential temperature sensors, repaired wire harness and replace a sensor. The transmission temperature sensor issue seems to be more difficult to find, the wire harness runs into the cab.
Can someone post a wiring diagram of the harness, I am not getting any voltage to the connector just above the batteries. Don't see any fuses in the box for the sensor nor do I have any blown, power must be coming for somewhere, but where?
Thanks in advance for your help.
FIXED 07 VT830 Transmission temperature sensor issue, tracing power
Discussion in 'Volvo Forum' started by sbreeden, May 7, 2019.
