FL60 Blowing White Smoke
Discussion in 'Freightliner Forum' started by hopilot, Dec 31, 2011.
  1. hopilot
    hopilot Bobtail Member
    fort pierce, fl
    Hello I have a 1997 Freightliner FL60 with a Cummings 5.9 2 Valve. At low RPM and low throttle settings it is smooth. At around 1500 RPM while acclerating the engine starts to miss and blows heavy white smoke from the exhaust. If you let up on the throttle to partial throttle setting the engine smooths out and smoke goes away. It is not using water. Turbo seems to be operating. Please advise
  3. Bill104
    Bill104 <b>Pepsiholic</b>
    719
    769
    Dec 27, 2011
    Sacramento,Ca
    Buy a.new turbo and check.your oil level, if a seal blows it only shows when you try to.pull, dumping oil that burns a heavy.white smoke, yet back it down.and nothing.seems wrong
  4. FLaster
    FLaster Bobtail Member
    Sounds like plugged fuel filter. This will lean out engine and cause white smoke.
