FL80/8.3 Cummins wiring
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by AModelCat, Apr 5, 2024.
  1. AModelCat
    164,934
    Sorry, don't have the VIN or ESN/CPL available.
    My neighbour called me the other day, having issues with no power to the fuel pump solenoid on his truck. I believe he said it was a 2000 or 2001 FL80 with an 8.3L Cummins. He says its a mechanical fuel pump on it but I can't confirm anything as I have not laid eyes on it yet. Just gathering some information right now.
  3. 062
    062 Road Train Member
    6,338
    33,982
    Oct 20, 2013
  4. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    Bosch p pump is an inline pump. Shut down solenoid has 3 wires. Hold in, pull in & ground. Pull in is a high amp
    circuit that's energized when the starter is engaged. Hold in has key power low amperage circuit. Typically if there's
    no key power to the hold in the engine will fire & shut off when you release the starter. No pull in the engine won't start
    but you can key on & manually pull the solenoid to run & it will hold. By 2001 I would expect it to be a caps fuel system
    which is very different. Electronic controls . Lots of pieces to it. Hopefully its older as caps stuff can
    be hard to get & expensive.
    AModelCat Thanks this.
  5. AModelCat
    164,934
    I think its a caps system. He said something about that but couldn't remember until you jogged my memory.
  6. Ridgeline
    22,744
    123,759
    2000 has a CAPS injection system, so it could be an electric lift pump (IIRR).
    https://www.thoroughbreddiesel.com/assets/1/pdf/troubleshooting-tree.pdf
  7. SmallPackage
    5,816
    18,633
    Dec 20, 2019
    Marion Texas
    The only wiring diagram i have for the business class is for Cat 3126 equip.
    AModelCat and 062 Thank this.
