Flashers not working.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jeffman164, Jun 18, 2024.
  1. jeffman164
    jeffman164 Medium Load Member
    620
    579
    Dec 4, 2012
    1999 International 9200. Flashers went out completely for about a full day. About an hour from home, flashers mysteriously started working again. Flashers worked for about two weeks then stopped completely. I have power to fuse and flasher relay while flashers are activated and also while not activated. Took flasher relay out and tested with motorcycle l battery. I can hear clicks so I assume that flasher relay is good. Can flasher relay still be good with hearing clicks ? Going to buy new relay anyhow just to make sure. Am I missing something as to why flashers aren't working ?
  3. FLHT
    FLHT Road Train Member
    1,408
    2,480
    Aug 2, 2014
    Was it raining ?
    Does your windshield leak ?
    Internationals seem to have a problem with water and fuse blocks.
    Moisture turns those relays green inside.
    Signal stat worn out ?
  4. Deezl Smoke
    Deezl Smoke Medium Load Member
    518
    338
    Feb 12, 2011
    Hillsboro Oregon
    Ground. Always inspect and clean every grounding point you can find and even some you can't when mysterious and randomly intermittent electrical issues show up.
    Deere hunter Thanks this.
  5. Heavyd
    Heavyd Road Train Member
    7,809
    6,260
    Feb 4, 2009
    The flasher relay isn't really a relay, we just call it a flasher. They can act up if you have a bunch of LED lights because LEDs do not draw enough current to properly activate an old school flasher. If you have regular lights, the next spot after the flasher is the actual signal switch on your steering column. After that the power is split up to multiple circuits, so I can't see a single ground or a single power wire after the turn signal switch going bad and causing all the lights to not work. You could be losing flasher power into the turn signal switch. Power from the from flasher is wire 55A at the turn signal switch. This is big 12 gauge orange wire. The wire on the signal switch side is black. You might be losing power here, or the turn signal switch itself is going bad internally.
  6. jeffman164
    620
    579
    Dec 4, 2012
    Installed new flasher switch - no go. Turns out the problem was at the connection close to the signal switch. Just unplugged and plugged back in. No green corrosion what so ever. Cleaned and applied dialectric spray. Works perfect.
    Thank you.
    Heavyd, Texasgordo and Deere hunter Thank this.
