Flat bed Equipment Advise
Discussion in 'Flatbed Trucking Forum' started by rdimas112377, Aug 31, 2013.
  1. rdimas112377
    rdimas112377 Bobtail Member
    7
    I started with a flatbed a couple of months ago but I have only hauled stone (locally only. I needed to start somewhere) Currently I carry 4" straps only. I want to go on the road and I wanted to know what other equipment should I consider buying. I have read about 3/8 x 20 chains with binders or ratchets (10), 2' straps (10 maybe), I have plenty of rubber tarp straps (140 different sizes) but i need help on Tarps sizes (? x ?) what dimensions would you advise? is there anything else you think I REALLY NEED to have to get started on the road?. I do have strap and chain guards. THANKS FOR THE ADVISE
  3. saddleup
    saddleup Light Load Member
    281
    137
    Sep 30, 2011
    magnolia, ky
    12 3/8 x20 chains split you binder 6 each incase you haul any military or equipment, no more than 5 2in straps as for tarps 8ft tarp loads don't pay anymore and in most cases pay less and are heck to do alone or in this heat waves we have'n 4 ft will do fine and get a smoke tarp.
  4. rdimas112377
    7
    On those tarps how many and what dimensions?
    thanks
  5. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    What kind off loads will you haul?
  6. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    I'm getting a couple of single coil bags. Using a full size lumber tarp or smoke tarp tends to be a big PITA. I'm still looking into a headache rack. Trying to find one I like that works for me has been a chore and still is. Trying to find a polished 3 door( "X" panel) with tarp rack on top that is no more than 12-14" deep.
  7. Skunk_Truck_2590
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    Typically and I see as a industry standard is two 24' lumber tarps with 8' drops and flap. They do have the newer three piece sets now but I don't know the dimensions but can say they are shorter in length but the same 8' drop with a center tarp which can be used in most cases as a steel tarp, smoke tarp or coil tarp. They are easier to work with weight wise as far as getting them up on the deck then on the load.
  8. rdimas112377
    7
    I would love to just haul loads that do not require tarps and only use straps, but having the tarps will give me broader options to find a load.
    There is nothing specific to haul.
    thanks
  9. blessedman
    blessedman Light Load Member
    296
    230
    Feb 15, 2013
    Doniphan, Mo
    I carry 12 sets of 20' chains and binders, a box (20) of 4" straps, about four 2" straps with ratchets which I seldom use and a winch bar. I also carry twelve 10' chains with hooks on one end (six 20' chains cut in two in the middle) for adding length to the 20 footers when hauling crushed cars. Also have a box of 50 rubber corner protectors that slide over the 4" straps. Also 4 four foot pipe stakes, ten 8' 4x4's hardwood and eight 4' 4x4,s. No tarps. I don't do tarp loads any more. Haven't for probably 8 years. Health issues.
  10. macavoy
    macavoy Road Train Member
    1,092
    1,956
    Jan 3, 2011
    Houston, Tx
    How much do you think this has affected your bottom line?
  11. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    12 3/8 x 20' chains
    8-10 snap binders
    4 ratchet binders
    10 - 2" straps and ratchets
    12 - 4" straps
    2-4 4" ratchets or stake pocket winches
    30 4" corner protectors
    16 Vee-boards
    8 coil racks
    8 8' 4x4's (prefereably beveled)
    that should be a good starting list, tarps are a bit of a coin flip. If you plan on hauling a lot of lumber or something that is going to require 8' drops then start with that. If not, then you really don't want to hassle with them and have the extra 400 lbs to haul around. 2 - 16x24's and 1 - 16x16 is also a good way to start, and if you add a 20x24 or 2 and a nose tarp you can fully tarp an 8' tall load by turning them sideways if you have too. It's fine to start without tarps too, you may miss some tarp loads but you'll also probably pick up some loads that need that extra 400-600 lbs net. Save your money, run awhile and see what you are missing out on by not having this or that tarp. I definitely wouldn't waste money on a coil bag unless you really plan on running coils alot, a 16x16 works fine and comes in handy as a nose tarp, for little partials, and for lots of things.
    edit - oh yeah, and furniture pads. tarps are expensive, furniture pads are cheap, buy the pads to cover sharp edges and corners so you don't rip your tarps.
    Hurst Thanks this.
