I am about to switch from dry van to flatbed. I would like some advice on which would be the best to start out with, flat or step. I run the western states, and am an owner operator with my own authority. My truck is a condo freightliner classic. I want to keep the condo for the room inside. I may hire a co driver to go coast to coast. I would like to hear from you guys who have experience with both flat and step.
Flat or Step?
Discussion in 'Flatbed Trucking Forum' started by areelius, Sep 2, 2013.
Depends on what you are planning to haul with it.
if step must have over 40 FT. on lower deck
I guess I would like to know which has more available loads. Which is more versatile, since I just run general loads from the loadboards. Which one is simpler and less stressful to load and haul with? I am in trucking because I enjoy it, and want to make it easier to find better paying loads than I can with a dryvan. I don't want to haul anything specialized. Just general freight.
Leave the dry vans, maing. Live off of 3 tarps per week and you'll be banking money for your kids. I have a few friends that drive reefer and want to quit because it pays 4k more per year. Don't get heart problems, though.
Don't drive short-sheets, though. Deliver 53'ers. Your lady might like it, too. Hard work.Last edited: Sep 2, 2013
53' step if you want to make money, and are willing to put time in finding higher margin loads. If you want to book cheap and easy freight and try to make money off low margin loads go with a flat.
areelius and WhiskeyTangoFoxnot Thank this. -
Please explain why?
Thanks Danny; do you have some estimate on what percentage the step might make over the flat, if I put the effort into the more specialized loads?
Step is god if you haul a lot of tall loads...flat is more versatile and can haul a bigger variety. step cant be dock loaded, flat can
areelius Thanks this. -
There are more flatbed loads than step deck. Rates for step deck freight is usually higher than for flats, but not always. Some shippers won't load a step deck but will load a flat. Loading a step is a little different than with a flat because of the upper deck. I have pulled both. I have a good friend who is getting very good rates pulling a flat bed. He does a lot of over size loads. The main difference between a step and flat is the height. You can haul a 10' high load with a step, but not with a flat. I would recommend starting with a flat and learn how to properly secure an open deck trailer. If you see that you could haul more freight with a step deck then you can buy one later. I carry a lot more on my step deck than I did with a flat. I carry more tarps, chains and binders than I ever had to carry with my flat bed. I usually do better with rates pulling a step, but there are good paying flat bed loads around.
Another consideration is the equipment cost. You can find a used flat bed for as low as about $5,500-6,500. You can easily spend twice that for a used step deck.snowwy, WhiskeyTangoFoxnot, BAYOU and 3 others Thank this.
