Flatbed equipment and rates ?
Discussion in 'Flatbed Trucking Forum' started by Greggg, Apr 29, 2019.
  1. Greggg
    Greggg Light Load Member
    161
    35
    Jun 30, 2018
    hey everybody
    I’m looking to get into flatbed. I’ve done some time back but not much and usually don’t mind working.
    On DAT it consistently says flatbed rates are higher than reefer was wondering what’s your experience?
    Also I was wondering what kind of equipment I need ?
    Like number and size of tarp straps ?
    Type, # & size of tarps ?
    What kind of chains and how many ?
    If you’d use tarp starp protectors or not ?
    blade and blairandgretchen Thank this.
  3. Gumper
    Gumper Road Train Member
    1,579
    3,847
    Jan 7, 2018
    Butte, MT
    The flat market is pretty rough right now in my area. Lots of low rates, or mediocre rates to dead zones (no backhaul anywhere close by). It’ll bounce back eventually, but who knows when.
    You’d probably want a two or three piece 8’ tarp set. I only have 4’ tarps right now. Eventually I’ll get some either 6’, or 8’. I get by fine though.
    I carry 20 27’ straps, and 6 20’ straps. Those 20’ ones are real handy for short loads, or gut straps. Have 19 sliding winches, 2 stake pocket portables and 2 2” ratchet straps.
    7 16’ chains, and 5 20’. Mix of ratchet, and snap binders. If did it again I’d get all 20’ chains with all ratchet binders. In my experience they are faster in the long run than snap binders.
    I also carry lots of miscellaneous stuff I’ve picked up. Couple dozen carpet squares, edge protectors, 6 8’ 4x4s, various blocks of wood, a good extendable ladder, two poly 10x12 tarps, 24” bungee cords, few bundles of ropes, a broom to sweep my deck after nearly every load and a winch bar of course.
  4. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Claw hammer and small box of double headed nails, or a screw gun and screws is handy too.
  5. JonJon78
    JonJon78 Road Train Member
    7,242
    43,050
    Jul 1, 2018
  6. Tug Toy
    Tug Toy Road Train Member
    7,077
    74,024
    Jul 4, 2015
    Corn field
    And you’ll need a good attitude about using all that stuff in the rain....... on a good day.
    But yeah, rates for flatbed on dat do “LOOK” better than van.
    blade, ChevyCam, HoneyBadger67 and 5 others Thank this.
  7. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    I'd add a smoke tarp to that list and some basic hand tools and extra marker lights for on the road truck/trailer repairs.
    Where's a good place to get 20 foot straps? I've been unable to source any locally.
    cke and D.Tibbitt Thank this.
  8. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Try truck or trailer dealers for straps. Paccar dealers seem to be better than FL on that stuff. $10 ea is good, sometimes you need to buy a box to get a deal, but you will use them eventually.
    blade, cke and D.Tibbitt Thank this.
  9. beastr123
    beastr123 Road Train Member
    2,952
    24,213
    Jan 2, 2014
    Moose Jaw SK CAN
    Buy the 30 ft straps and trim them... the trimmings can be used to pad chains or protect straps from sharp edges if cut into 12" to 18" pieces. I cut older straps down and cut the trimmings up and toss any worn or damaged areas when cutting. You will find that you will need about 6 "shorts" and in about 2 years of normal wear you will have 10 or 12.
    Use a propane torch to fuse the ends so they won't fray. I use a heavy putty knife blade after the torch to smooth the hot ends and protect my fingers.
    blairandgretchen, shogun, cke and 2 others Thank this.
  10. Tug Toy
    7,077
    74,024
    Jul 4, 2015
    Corn field
    I always say I’m going to cut down some damaged straps but they always get damaged at 8’ to 10’ which makes them useless.
    Lol
  11. D.Tibbitt
    157,285
    Get a box of bungees for ur tarps,.. Start with about 100 bungees that should do u well... I like the smaller ones bettee i think their 15inches , the bigger ones when they stretch out they get to long and become useless. When the smaller ones stretch out they are perfect size.. Plus when they are new the keep everything real tight
    QuietStorm, blairandgretchen and cke Thank this.
