Flatbed-Intrastate Only-Ohio
Discussion in 'Ask An Owner Operator' started by PIB317, Oct 18, 2022.
  1. PIB317
    PIB317 Bobtail Member
    Hello All
    Brand new to the site. First off thank you to all with the knowledge I’m after. Currently I’m a leased OO DV. The plan is in early 2023 haul strictly my own 48’ flatbed(unless suggestion change that to a step and/or 53’) and only run intrastate loads in Ohio. Reasoning behind intrastate only is the flatbed is needed for the second business I have stewing in the ol noggin. Plan to haul mostly equipment. No coils or trapping.is it possible to make decent money. Not get rich pay the bills while I work on the second side of the business?
    thanks
  3. Jubal Early Times
    3,069
    20,583
    Oct 17, 2022
    It’s been my experience that if you are planning only doing intrastate in Ohio you better rethink the “No coil” policy. Steel has always been consistent for local Ohio work.
  4. Eight Omens
    Eight Omens Light Load Member
    163
    371
    Oct 10, 2022
    Central Texas
    I agree with what Jubal said. The 48's are nice, but you may want to consider a 53' step. Each trailer has adv. disadv. The 53' step can give you a wider variety of loads if you get into a bind and need to change up a contract. I would also reconsider tarps for the same reason you know the old saying, better to have them and not need them than to need them and not have them. Again that is about being able to adapt when a market changes. If I remember correctly there are some receivers/shippers right across the OH/PA border when I was running fb a few years ago. Ohio was pretty good for fb but it might be worth it to check into PA for a bit of versatility. If things are like they were when I was driving just those 2 states you should be ok with fb. Me personally I would not limit to intrastate OH only just because I like a plan B incase plan A hits the fan. In those 2 states though its lots of steel which will require a Conestoga or tarps per shippers and receivers much of the time. Everyone's situation is different, and with the info you gave about your plans the considerations I provided are just that and hope it gives a constructive opinion to consider. Best of luck to you.
  5. PIB317
    To you and jul
    Thanks to you and Jubal.
  6. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    A lot of shippers have stopped loading big coils on flatbed they want stepdeck trailers for the 6ft long gav. coils going to the BMW plant in SC. They are just closer to the ground and will not turn over as easily?
    PIB317 and 77fib77 Thank this.
  7. fortycalglock
    fortycalglock Road Train Member
    6,155
    6,584
    Jun 25, 2011
    Tourist Town, FL
    Keep in mind with 53’ platform trailers you get KPRA axle issues, especially up that way.
    Eight Omens Thanks this.
  8. Eight Omens
    163
    371
    Oct 10, 2022
    Central Texas
    Have they changed the KPRA laws up there for the fixed spread axles? When I ran up there years ago, I did not have a problem with the 53s as the axles did not slide. If I remember correctly a sliding fifth wheel placed further back was good to go. I know on 48s with sliding tandems in FL they had to be closed and maybe a few other states as well, but never had an issue with 53 steps. I would hate to give bad advice or info so thank you for any info you can share.
  9. Jacoooooooo
    Jacoooooooo Heavy Load Member
    747
    1,054
    Oct 20, 2013
    You will loose too much time on loadings / unloadings on loads like this, to keep the other business running. If it was that easy we would all be home 16h a day.
  10. Kenworth6969
    2,773
    8,006
    Jul 3, 2020
    No coils, no tarping and staying in Ohio, might as well go bankrupt now and save yourself a headache.
  11. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    First I’ve heard this but the center of gravity makes sense as to the reason
