Flatbed mods to make it easier to load / unload
Discussion in 'Flatbed Trucking Forum' started by blanco, Oct 24, 2012.
  1. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Sliding winches are good, but the ones over the tires rub sometimes and I saw another flatbed with a really nice setup to avoid the tire damage.
    I'm thinking about doing this mod to my flatbed. I guess the only drawback would be the "devaluation" as perceived by others.
    What other mods have you guys done to make it easier to load/ unload.
    Thanks!
    MackDaddyMark Thanks this.
  3. blanco
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    How about homemade v-boards? Can someone post a how to: utilizing old straps and some 1x4's?
    Measurements would be nice.
  4. TripleSix
    133,282
    V boards, you need eight pieces of 1x4 cut to 4 ft and twenty at 8 ft long. That should be enough to cover a 48 ft flat skateboard front to rear.
    botoler and blanco Thank this.
  5. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    Why bolt winches to the side of the trailer to clear tires on occassion? That is why they invented the ratchet strap, or the porta-winch.
  6. TripleSix
    133,282
    Or the stake pocket winch. A few years back, I went into that Petro thats to the east of Kansas City. I went browsing through the flatbed stuff and noticed that they had the stake pocket winches marked for $19.95 each. I knew that just had to be a mistake. I took one up to the cashier and asked her to check the price. When she told me $19.95, I went back and got 5 more. They work great around the tires on a stepdeck.
  7. QuietMike
    QuietMike Medium Load Member
    371
    165
    Oct 21, 2009
    NE Ohio
    Some of our curtain sides have the first four and the last four winches bolted into place. It really is more of a pain, I think.
    npok and SHC Thank this.
  8. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    I've never had a winch touch a tire on my wagon, and I have them directly above them all the time. Sounds like maybe you got some 5th wheel height issues???
    the only thing I've found yet to help me speed up the process was a strap winder for when I'm done. I used to roll them up by hand but then got smart and spent $12 on one and now I couldn't live without it.
    Homebrew and MichianaFlat Thank this.
  9. Noggin
    Noggin Road Train Member
    2,494
    977
    Apr 10, 2011
    Houston, TX
    Yep. Only time my winches hit my tires are the rear axle on our 48 footers, cuz the trailer dumps when you set the brakes.
    And V-boards...like he said get 4 and 8 footers, cut you some old strap about 6-8 inches, and just tack em into the boards...
    SHC Thanks this.
  10. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    Mine has a bolt through the rail to stop sliding over the tire. I just grab a Portawinch when I need astrap there. Wish I found some for 19.95!
    SHC Thanks this.
  11. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    I carry a couple stake pocket winches and 4 - 4" strap style ratchet's. and all that $#*t cost me more than 19.95 a piece but worth it ! why cut your rails apart when you can just put a 4" ratchet strap on ? If you don't know, it's just like 2" straps except 4"
    oh, and vee-boards you can just use roof flashing or just get a sheet of whatever gauge steel you like and shear to whatever size you like and press it to a 90 degree. I kind of like the plastic ones though, because if it's windy, steel ones are likely to cause head trauma and pools of blood if they blow off.
    SHC Thanks this.
