Flatbed trailer weight
Discussion in 'Flatbed Trucking Forum' started by fencitup, May 14, 2014.
  1. fencitup
    fencitup Light Load Member
    225
    113
    Jan 12, 2014
    Bronx, NY
    Just about made up my mind on a 2015 East MMX 53' all aluminum flat trailer.
    As spec'd 11,300 lbs. - 2 boxes / NO tire carrier / NO headboard
    Does this seem heavy? If so, is it to the point of being restrictive ?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    How much does the truck weigh out at?
  4. fencitup
    225
    113
    Jan 12, 2014
    Bronx, NY
    Will find that out in another week or so. Will be a new Pete 587.
  5. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    that seems awful heavy to me by about 2000 pounds
    Big John Classic HQ Thanks this.
  6. mc8541ss
    mc8541ss Road Train Member
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    That is a couple thousand heavier than my MAC with 2 boxes. With my 379 I can haul 50,000 lbs. truck and trailer comes in at 29920 lbs. with my Great Dane 48' combo I weigh 32800 lbs.
    That East seems heavy for an all aluminum trailer. You want to be able to get 48000 lbs min and 50000 give you a few more options especially when doing Ltls.
  7. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Why do you want the mmx? I specc ed out a 53 alutrec capacity it came to 8600 lbs with independent sliders, a toolbox, a lift axle, and I think they're rated for 60k in 4.
  8. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    The extra 5 feet probably adds 1000 lbs plus the mmx beam another 1000 or so. The only reason to go mmx in my opinion is when you're doing a 4 or higher axle setup. The decks on those trailers is way higher than most aluminum flats.
  9. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    He needs something that won't break dragging it over the BQE everyday!
  10. fencitup
    225
    113
    Jan 12, 2014
    Bronx, NY
    Ha, that's a good one. That's the case for most all the roads around NYC, its a sad state of affairs. But...home is home.
    x1Heavy Thanks this.
  11. fencitup
    225
    113
    Jan 12, 2014
    Bronx, NY
    Can't argue with you on the weight savings between the MMX and your trailer, that's a huge difference.
    I was going with East for their reputation and quality of product. The Beast II or MMX are the two models I narrowed it down to. The Beast II can handle most anything that you would put on a flat with a rating of loads up to 50,000 lbs. concentrated in 4 feet on a 48-foot long trailer, and up to 60,000 lbs. I don't know what the MMX CAN'T handle being rated to handle loads up to 72,000 lbs. concentrated in 4 feet on a 48-foot long trailer, and up to 145,000 lbs.
    With all that in mind the difference in weight between the two is less than 200 lbs. The difference in price I was quoted was exactly $2000. So, all things considered led me to settle on the MMX. The shock came in the weight of both. As long as the weight of the trailer won't hinder me, I think its definitely the way to go.
    I am open to advice, hence why I started the thread. Someone on here may open my eyes to something better that may save me a ton of heartache down the road.
