Flatbed with a Volvo 780
Discussion in 'Flatbed Trucking Forum' started by mxpx148, Jun 29, 2017.
  1. mxpx148
    mxpx148 Road Train Member
    1,232
    759
    Oct 2, 2013
    NEPA, PA
    Anyone on here pulling flat with a Volvo 780? Would there be a problem pulling 46000 lbs with a 10500 lbs 48' flat? I know they are a bit heavy, but currently pull a van and no experience with flat. TIA
  3. TripleSix
    133,510
    Consider these things
    Wheelbase
    Kingpin setting of the trailer
    How much room you have between the sleeper and the 5th wheel
  4. mxpx148
    1,232
    759
    Oct 2, 2013
    NEPA, PA
    Trailer would have a 30" kingpin inset, looking at a Volvo with a 233" wheelbase, and a 579 80" sleeper with a 235" wheelbase. Sticking with van for now, but also keeping my options open for flatbed.
  5. mxpx148
    1,232
    759
    Oct 2, 2013
    NEPA, PA
    Space between center of drive axles to rear cab on Volvo is 96.4 "...don't know about the pete
  6. mxpx148
    1,232
    759
    Oct 2, 2013
    NEPA, PA
    Back of cab to front axle on Pete is 74.1
  7. TripleSix
    133,510
    I would go with a loger wheelbase 579. Shortest I would run iss 244 wb
    cke and Razororange Thank this.
  8. mxpx148
    1,232
    759
    Oct 2, 2013
    NEPA, PA
    Unfortunately, those are the only options I have. Would that wheelbase cause scaling or clearance issues?
  9. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    I have a w900 that is 20500# with fuel,244 inch wheelbase a 48ft spread @9100# with a 24 inch king pin and no problems can load 49,000 with half tanks of fuel.
    mxpx148 Thanks this.
  10. TripleSix
    133,510
    There will be issues with the front overhang. You will need the wheelbase.
    If you are the one paying the bills, you ALWAYS have other options. If dead set on a Volvo, I'd want a walk in midroof, 244 or longer wb, minimum 500 HP NON VOLVO engine. If I am paying the bills, I will get what I want, or I walk. I want it owner operator spec, with 22 gauges on the dash, no idiot lights. There is a reason why owner operator spec'd trucks come with gauges and mega fleet company trucks come with idiots lights. Do not pay money for an idiot spec'd truck.
  11. mxpx148
    1,232
    759
    Oct 2, 2013
    NEPA, PA
    I'm leased on to Schneider and lease my trucks through SFI. I agree with you 100%, unfortunately I don't have the $30k+ I'd need to spec one straight from the manufacturer, so I'm kind of stuck with what they offer..they require EPA2010 or newer and I'm not to fond of buying a used emissions truck. I'm doing well over here, but my current lease is up in Oct and I'm going to need another truck, and I am considering going over to Mercer in the Spring to try out flatbed.
