FLD 120 won't crank when cold
Discussion in 'Trucks [ Eighteen Wheelers ]' started by W Bench Farms, Dec 22, 2024.
  1. W Bench Farms
    W Bench Farms Light Load Member
    211
    351
    Oct 16, 2017
    I have an FLD 120 with a 3406E Cat. New Delco starter about 2 months ago. Batteries are about a year old, and were all tested and good about 1 month ago. Has never had a problem starting down to 15-20 degrees without being plugged in. This week we have had lows down in the teens. Truck will just barely crank, and not fast enough to start. If it's warm, or truck has been started that day, no issues. The only other thing that I can think of is battery cables dropping voltage. Any good way to test?
  3. AModelCat
    164,717
    Connect a multimeter between the positive battery post and the starter. Should read close the zero volts when you crank. Any voltage that you see on the meter is considered a voltage drop.
    Check from the battery positive post that is furthest from the starter. Also, check at the other side of the starter solenoid (leading into the starter body) as well. Then do the same for the negative side. Negative battery posts to the starter frame.
    Generally a maximum of 0.7 volt loss (0.5 volts for cables and 0.2 volts across the starter solenoid) is permissible for the entire starter system.
  4. Rideandrepair
    17,562
    56,898
    Aug 8, 2015
    First thing to do is check the terminals. They often get loose. Give them a twist and tighten if loose. If they’re the original style, the ends may be corroded under the plastic covering. Next, look for a positive cable, (probably have 2 of them) that’s worn through the sheathing and grounding on metal. Often the battery box itself. If so, tape it up, protect with old heater hose. Might want to check distilled water in those new batteries. One of those things has always worked for me. New cables are best on an old Truck. You can always run a set of jumper cables from positive battery to positive on starter. See if it cranks better.
    Bean Jr., Iamoverit and Deezl Smoke Thank this.
  5. Deezl Smoke
    Deezl Smoke Medium Load Member
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    Warms and colds often indicate a loose or corroded ground strap. When cold the metal shrinks leaving a loose connection, then once the high amp draw of starting warms it up the metal expands and makes a tighter connection. Corrosion works similar.
    Since the starter was recently replaced, go to it and check the connections there first as one or two of them may have loosened.
    If you drive in much salt, any cable that were made using a shrink tube at the crimped ends, often leak and salty water will get behind the shrink tube and make a mess that you can't see.
  6. 062
    062 Road Train Member
    6,330
    33,970
    Oct 20, 2013
    If your ground is to a stud tack welded to the frame,find a nearby hole,knock the paint off and bolt it there.
    Rideandrepair, Heavyd and Deezl Smoke Thank this.
  7. wore out
    wore out Numbered Classic
    17,329
    215,215
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Freightliner grounded to the frame if i remember right. That was always the spot we seemed to find the trouble was one ground studs on the frame.
    Rideandrepair and Bean Jr. Thank this.
  8. SmallPackage
    5,786
    18,579
    Dec 20, 2019
    Marion Texas
    We would run a 0 ga. Jumper from battery ground stud to starter ground studs on frame or run second 0 ga. cable from one of the batteries straight to ground stud on starter. Works wonders but even down here where we aren’t in your cold plugging in the block heater a little while before fire up if you are cranking on only 3 or less batteries helps a lot.
    Rideandrepair Thanks this.
  9. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    I'll just jump onto the pile of comments about bad ground connections too. LOL.
