FLD 4th air tank
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Trugo, Mar 25, 2019.
  1. Trugo
    Trugo Light Load Member
    71
    50
    Dec 8, 2015
    Is anyone familiar with a 4th air tank on a feightliner FLD? This tank has only one hose connected and holds air. Is it safe to remove? Purpose?
    Also, would I expect my trailer air supply to come from the wet tank, or the primary tank?
    air noob here, trying to learn more.
  3. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Here is a basic air system diagram. If needed Antilock brakes, roll stability, Automatic Traction Control; Control this system with modified or inline added valves but still have to follow this basic schematic.
    All air operated accessories come off the secondary system with a 60-70 psi pressure/ check valve. (Meaning until the system pressure is above the threshold, the air won’t pass)
    So there’s an air system but shell.
  4. Trugo
    71
    50
    Dec 8, 2015
    That’s a good diagram. So, the trailer air tank supply comes from both primary and secondary tanks via the double check valve. Is this correct?
  5. AModelCat
    164,770
    4th air tank. Is it smaller than the rest? Might be a purge tank for the air dryer. Trace the line and see where it leads. Might give us a better idea.
  6. Trugo
    71
    50
    Dec 8, 2015
    Yea 4th tank, not smaller it’s the same size as the wet tank. I’ve heard of another guy with an fld who has a 4th also. The Truck is in for the annual inspection so I can’t take a look. But I tried to trace it before, it would be hard without some disassembly. Air dryer purge hey. Maybe although my ad9 purges directly below.
    The truck has 3 tanks behind the cab, the wet tank, the secondary tank (small) and then this mystery tank with only one hose. The primary tank is behind the 5th wheel. I think that’s how it works anyway.
  7. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Drain each tank one at a time and watch your gauges is easy way to tell.
    SAR, BoxCarKidd and Trugo Thank this.
  8. Trugo
    71
    50
    Dec 8, 2015
    Ok good idea
  9. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    With only 1 line going to it, sounds like just extra capacity to me. Would make the compressor work less.
  10. Trugo
    71
    50
    Dec 8, 2015
    Makes sense. So it makes it a double size wet tank.
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    No. If you need secondary air it cannot pull off the primary.
