FLD120 clutch adjustment linkage question
Discussion in 'Freightliner Forum' started by 55_cans, Sep 20, 2012.
  1. 55_cans
    55_cans Light Load Member
    98
    19
    Sep 14, 2012
    Alberta
    Does anyone know whether the FLD120 clutch linkage bar that runs from the engine compartmemt to the transmission is normally straight or curved? And a shot in the dark, the normal length of the bar without the adjustment eyes.
    Mines been repaired by a prior owner and I do not know if the bar was repaired properly.
    The freightliner P/N is A02-09868-015 $275, the parts rep couldn't answer these questions.
  3. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    It's straight. I could measure it tomorrow. I have FLD120.
    That's the high price, then they charge you $137.50 and you think you got a great deal!
    You can make your own for less than $50 and that includes two new ends.
    55_cans Thanks this.
  4. 55_cans
    98
    19
    Sep 14, 2012
    Alberta
    Thank you.
    If you could measure it, that would be very much appreciated. Mine has been modified but it appears like it used to be one piece of 5/8" square bar. I'm after the length of the bar, that the eyes screw into.
    I can reuse the eyes, so my cost would be 25-26" length of 5/8" bar (guessing at approx. original length). Just have to cut to length, drill and thread the ends.
    I drove two hours to see another FLD120 today, but it was out on a fuel run, my bad luck.
  5. Semi Crazy
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    Sorry, forgot about ya.
    Actually it's not straight. I just looked in the svc. manual.
    It's bent about 2/5 of the way from the top I'm guessing maybe between a 10 and 15 degree bend.
    The bend is to clear the cab floor.
    Really the exact length is not important. What matters is that you get the correct play measurement at the pedal. That should only be checked when the clutch is first properly adjusted.
    Register at http://www.accessfreightliner.com/ and you can view all the service manuals service bulletins, etc. It's a PITA tho cuz you gotta log in every month or your account gets inactive and deleted.
    Then you can check your clearances. I don't have time to post all the info.
  6. Semi Crazy
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    I restored my account there. Here ya go.
    Full page fax print1.jpg Full page fax print2.jpg Full page fax print3.jpg Full page fax print4.jpg Full page fax print5.jpg Full page fax print6.jpg Full page fax print7.jpg Full page fax print8.jpg Full page fax print9.jpg Full page fax print10.jpg
  7. 55_cans
    98
    19
    Sep 14, 2012
    Alberta
    Thank you very much for the info and pictures. I think can get the length from the drawing, by scaling it from a known, like the cross-shaft lever arm. I'll look into that account too.
  8. 55_cans
    98
    19
    Sep 14, 2012
    Alberta
    I did this, but it'll take a some days to receive an account and access status. Info available on site looks good. Thank you.
    Semi Crazy Thanks this.
