fld120 steering problem ! pls someone help me !
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lmfnj, Apr 19, 2012.
  1. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Since you have confirmed that you have no mechanical binding or interference problems and the truck steers when not rolling, I would locate the best alignment tech you can find and trust to set your caster to optimum spec and I think you'll have your problem solved.
    It is common for some shops to overlook caster due to adjustments being labor intensive, so they let it slide, but when you carry a lot of weight on the steering axle it will definitely show when you don't have enough and I am assuming you have a headrack which requires your alignment to be to optimum spec.
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    The steering box and the idler arm have a neutral spot, if in replacing all that you have done that setting was lost, it will make it steer goofy.
  4. lmfnj
    lmfnj Bobtail Member
    41
    Union NJ
    i agree caster is something overlooked/not done correctly at most shops, iv'e been looking around for a place but no luck so far, i did find a truck collision repair shop that might help me since they assemble the truck almost from the ground up :/
  5. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    There was a great alignment thread in here last year. Went into more details about caster. I know some techs will set each side slightly different sometimes.
    The steering box shafts have marks so you can check if the box is really centered and not just the steering wheel.
  6. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
  7. Fatboy42
    Fatboy42 Light Load Member
    281
    389
    Feb 9, 2011
    Indiana
    Has the truck ever been wrecked and repaired. I worked on w900 tri-axle doing same thing had front frame splice drilled wrong putting all in binde had them take back to dealer that did repair, they re did work now fine.
  8. lmfnj
    41
    Union NJ
    I have no idea if its been wrecked, im going to do some measuring today, I really need a good alignment shop here in nj.
  9. Semi Crazy
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    If you come to Nashville, TN I can hook ya up!
  10. lmfnj
    41
    Union NJ
    @Semi Crazy i wish buddy but with this steering I wouldn't make it to TN :)
  11. lmfnj
    41
    Union NJ
    i understand the caster thing, but would it also cause the steering wheel to be hard to turn, its equally hard to turn at 1 mph and 70 mph
