fld120 steering problem ! pls someone help me !
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lmfnj, Apr 19, 2012.
  1. lmfnj
    lmfnj Bobtail Member
    41
    Union NJ
    i have trw box, how do i adjust it ? i have tried the screw in the back with the nut on it i reversed it a bit a few times but it didn't make and difference, is there any other adjustments ?
  3. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    That is the only external adjustment. Keep in mind while making adjustments that you need to steer completely from lock to lock then back to center to see any change from the adjustment you made, otherwise you will think you made no change until later when you drive the truck and internals get seated from steering load.
  4. bender
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Make sure your 5th wheel is lubed, dry spots can cause this also.
  5. lmfnj
    41
    Union NJ
    it does this without the trailer :/
  6. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    See, your doing all this messing around, taking things apart and just guessing. Take your truck somewhere and have the caster measured!
  7. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    Sounds to me like a kingpin is binding up on you.
  8. lmfnj
    41
    Union NJ
    ok so i got the caster checked and redone and guess what same thing :/ the shop told me my caster is good 5.25 and 5.75 on right, they also told me the steering wheel feels stiffer then its supposed to, they reved the motor up to see if the steering would become easier but nothing :/ wtf is going on ??? pump is new and putting down good numbers, lines are clear and filter is new...
  9. lmfnj
    41
    Union NJ
    i don't have the nerve to deal with this anymore, if you're a mechanic that can fix this issue, i have 1000 cash in my hand, <phone number no allowed>
  10. Heavyd
    7,826
    6,276
    Feb 4, 2009
    Well, for it's worth, I thank you for at least listening to me and getting your caster measured, I appreciate that. I am sorry to hear it isn't the problem, but at least now we know it is good. We just had a truck in for something like this a couple of days ago and we found the slip joint in the steering shaft was seized and causing the steering to be stiff and not return to center. The shaft needs to slide in an out a bit as the ujoints turn and the seized shaft prevented this and caused the problem. Simple check, remove the steering shaft at the input of the gear and just try to pull it out and push it in to see if it will move freely. I understand your frustration, I'll try my best to help out.
  11. lmfnj
    41
    Union NJ
    thanks buddy, it's just that i'm ready to loose my truck due to not being able to drive it safely and i'm really frustrated, i have tried the shaft and moves good
