fld120 steering problem ! pls someone help me !
Discussion in 'Trucks [ Eighteen Wheelers ]' started by lmfnj, Apr 19, 2012.
  1. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    So you had this problem before, and after you changed the p/s gear box? Did you have your gear rebuilt? Very rare to have the same problem after culprit part has been changed! But, I hope to God you have found it! (I'm not religious, by the way... just saying)
  3. Heavyd
    7,829
    6,280
    Feb 4, 2009
    If the gear is bad again I recommend a complete system flush, all new fluid and filter. You should take the p/s reservoir right off and clean it completely out too. A lot of sediment can build up at the bottom in many types of reservoirs. You may have a bunch of pieces of an oring or seal that broke down and floating around reeking havoc!
  4. lmfnj
    lmfnj Bobtail Member
    41
    Union NJ
    this is the third box and it feels the same as the original one and the second one, i took everything apart and flushed everything out, i mean i even had all hoses and tank go thru the parts washer and new pump installed, new fluid filter and after that pressure checked @2300 psi, still the wheel is still and box feels like it sluggish and sticky to any position, so next step was steering column, i disconnected the steering shaft to try to isolate the problem to the column, but to my surprise it spins great. wtf am i missing here ?!?!? (all three gears where different ones, but all were rebuilt)
  5. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Unfortunately you would need to disassemble the gearbox to confirm the problem and that would void the warranty. Are there any traces of debris in the filter? The filter being on the return side would allow trash to go through the gear before filtration. Does the truck have a PS cooler? Is there a possibility that one of the PS lines has developed a fissure in the inner lining holding trash and then allowing it to enter the system after it has been flushed?
  6. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    When you replaced the gear box did you set it up correctly? You have to set the plungers in it. You'd have to read the instructions as I can't remember exactly how to do it but I do know we had to do this on my dad's truck. We didn't do it right the first time and the steering was sticky and wouldn't turn all the way to the left.
    There should also be an automatic bleeder/breather on the gear box, make sure its there.
    Think someone already said this, but make sure there is nothing blocking the passage ways for the fluid. They come with those plastic inserts to keep dirt out.
    I'm thinking you have something wrong with the pump itself, not the gear box...
  7. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    You could try ditching the TRW and using a Ross box. Disassemble/flush/clean the whole system before putting it back together.
    You could grab one from a junkyard just for sh--- and giggles.
  8. lmfnj
    41
    Union NJ
    already tried, i found a nice looking ross box from another fld, i hooked it up and it was even harder to to turn, but it would bind when i tried turning to the left, i looked up this problem in the "guide to easy steering" and saw that this could be cause by internal leak or poor fluid supply, i cleaned the system sooo many times and never found anything, the pump is new (the old one did the same as the new one) ...... the lines are clear as well you, can actually see thru them.......
  9. Hurricane69
    Hurricane69 Road Train Member
    4,421
    59,740
    Sep 10, 2008
    Iowa
    Sounds like you got air in the system. Probably from a seal leaking in the pump. Every old straight truck I ever drove did this at one time or another. My old '83 brigadier dump does it now. No more than I use it I just deal with it but it don't go far and usually on gravel.
    SAR Thanks this.
  10. Heavyd
    7,829
    6,280
    Feb 4, 2009
    I wonder if maybe the p/s lines or a fitting is too small and restricting flow?
  11. lmfnj
    41
    Union NJ
    ......anyone else any ideas ???
