flickering daytime running lights with parking brake on
Discussion in 'Western Star Forum' started by skman, Aug 6, 2015.
  1. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    If you "do it at the switch" your parking brake light wont go out on the dash. :(
  3. Cetane+
    1,304
    882
    Sep 29, 2013
    Albany, NY
    Does your red park brake light and day time running light flash at the same time your headlights do when your parked? I wonder if its more of the internals of the ECC than the pressure switch. Maybe the switch doesnt open as much as it needs to and has a slight contact that makes the ECC go on and off, over and over again.
  4. Captain Canuck
    Captain Canuck "Captain of the Ship"
    854
    541
    Apr 7, 2007
    Woodstock, NB, Canada
    Mine did this for a while. The switch on the air valve was shorted.
  5. Star4900
    Star4900 Medium Load Member
    617
    541
    Mar 16, 2015
    Northern Ontario
    Fell asleep early after work. Good thing I woke up. looked out my window to see part of my parking area lit up.
    Went outside and my headlights were on but switch was off and parking brake on.
    Had to pull the breaker for the daytime running lights.
    Guess my switch finally went for good after flashing from day one brand new.
  6. Star4900
    617
    541
    Mar 16, 2015
    Northern Ontario
    On mine it is only the headlights, does not affect the running or tail lights. Pulling the breaker out does away with the daytime running lights and doesn't seem to affect anything else.
  7. Cetane+
    1,304
    882
    Sep 29, 2013
    Albany, NY
    I mean the indicator lights on the information strip on the dash. There is a red park brake light and a green daytime running light indicator icon light.
  8. Star4900
    617
    541
    Mar 16, 2015
    Northern Ontario
    Oh sorry, misread that. Yes when it does screw up the park light on the dash also goes on and off.
    free2fly973 and Cetane+ Thank this.
  9. AModelCat
    166,498
    Just a thought I had but have any of you with this issue tried a new pressure switch with a higher pressure rating? Like maybe 75-80 psi?
  10. IH Truck Guy
    5,199
    60,728
    Mar 2, 2008
    Purgatory
    Star has a service bulletin that shows the proper way to eliminate the DRL.
    I'll see if I can dig it up and post it.
    I can figure out all by myself when I need my headlights on.
  11. Star4900
    617
    541
    Mar 16, 2015
    Northern Ontario
    Simply pulling the breaker seems to work. Never affected any other circuit. The breaker is clearly listed on the dash cover panel.
