flying j exit 323 winchester va
Discussion in 'Truck Stops' started by stogey1945, Mar 22, 2012.
  1. stogey1945
    stogey1945 Bobtail Member
    37
    5
    May 29, 2011
    Salisbury, Ma
    To the idiot Western Express driver. Who can't figure out his hrs. So he had to put his vehicle in the most inconvenient place in the lot. That's blocking everyones else from moving around the lot. If something happens to your truck. It may be the persons fault for taking justice.
    But you and your vehicle deserved it. Good luck to you.
  3. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    That place is beyond ###### up. I was there earlier this week and it took me 20 min to get out in the morning.
  4. ghostrunner
    ghostrunner Light Load Member
    59
    23
    Dec 17, 2011
    Ga
    Yep I only stop there if I have too.
    Sent from my iPhone 4
  5. Dstraw
    Dstraw Bobtail Member
    43
    19
    Feb 27, 2012
    Somewhere
    That is a Western Express requirement.
  6. seven770
    seven770 Bobtail Member
    21
    9
    Feb 24, 2012
    Take a look at the google maps satellite photo of this place....looks like a total cluster mess going on there.
  7. hawkjr
    hawkjr Road Train Member
    1,652
    638
    Feb 28, 2010
    Virginia
    tight as hell in that truck stop!!! i suggest if your heading south and gotta fuel at a Pilot/Flying J, go ahead and stop at exit 5 in MD, they are only 30 miles apart and alot more room!!!
    also if you need a place to stay, not saying you have to go inside to spend money, but there's a strip joint on U.S. 11 right across the WV line that has a pretty good size lot.. Trucks park in it all the time
    48Packard Thanks this.
  8. PackRatTDI
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    Im not sure which was worse, the Winchester J or the one in Gulfport, MS last night. My God!
