Flywheel vibration
Discussion in 'International Forum' started by Dadetrucking305, Apr 12, 2021.
  1. Truckers Report Jobs
  2. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    984
    2,585
    Sep 15, 2011
    Cibolo,Texas
    It’s a 2004 ISX cm870.Heard the noise when I went to park for the night and crawled under the truck to figure out what the source was.
    Rideandrepair Thanks this.
  3. Rideandrepair
    17,582
    56,950
    Aug 8, 2015
    I did a whole new clutch, flywheel, throwout, everything on my 13 spd. It sounded the same. I also took a video like you, thinking something was wrong. Ofcourse I can’t tell exactly how loud yours is. But if it’s only loud with the cover off, it’s probably normal.
  4. Rideandrepair
    17,582
    56,950
    Aug 8, 2015
    Did you take the inspection cover off? Or has it fallen off, and is missing. And that’s why you’re hearing the noise.
    baha Thanks this.
  5. Ridgeline
    22,769
    124,437
    Most likely it isn’t the flywheel, unless you took it off and beat it with a hammer and then took a drill to it.
    The harmonic damper is the cause more times than not. These should be replace between 500k and 750k. They cost around $600 and take time to install.
    I’ve replaced a few and have had them replaced many times.
    Heavyd Thanks this.
