Can someone here answer one regarding what I saw yesterday morning?
I was driving out of Seattle southbound in the usual heavy traffic. A tanker came up on my left and passed me. Didn't concern myself with it until I saw what I assume was raw milk splashing out the edges of the dome occasionally, and then I noticed trails of it running down the side of the trailer.
I was in another truck, not my own, and the radio doesn't work. There was no way for me to get over to try to get up to him, and he was outpacing me pretty well. There were no company markings on the trailer, otherwise I would at least have been able to figure out where to call.
I'm guessing the driver failed to secure the dome, and this load was probably rejected once it got to it's destination for contamination?
Food grade question
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by JReding, Aug 15, 2017.
Page 1 of 3
born&raisedintheusa and JReding Thank this.
Probably didn't secure the dome lid. Or could have had a bad dome lid gasket.
JReding Thanks this. -
Yeah, so far as I'm aware food grade doesn't vent unless you're unloading (or loading through the discharge pipe.)
I use an old milk trailer to haul def. they don't have vents. I have to open the dome every time I dump. He probably just had a bad seal, there isn't really any other way it could leak up there. I doubt he took off with it open.
I'm sure it wasn't open, but I'm wondering if maybe he got distracted from the time he closed it, and maybe forgot to secure the swing bolts(?) Whenever there was a surge, about a half a gallon at a time would splash out. Could that much come out with a bad seal? -
One of the things I get to do regularly is open the hatch on my full tank and drive across a field while draining my load. So I do have some practical experience here.
If the driver failed to secure the hatch he would have gotten a heck of a geyser at first stop sign he met. As the load surged forward and built against the front of the tank "Old Faithful" would have blown. It would be hard to miss.
A gallon spraying out every once in a while argues strongly for seal damage or loosely tightened dogs on the hatch. Just enough to vent some product each surge.
A remote possibility (anything is possible, lazy is lazy) is he got over loaded and the product spilled over the top but the drains were clogged and he didn't bother to take care of it. That would lead to liquid sloshing around the hatch tray and splashing out.
Then there is the combination of the two: Small leak filling the tray which had blocked drains.
In any case his trailer should have been piddling on the road if he was leaking from the hatch or vents and his drains were working.JReding Thanks this. -
Page 1 of 3
