Forced Catheterization Used In DUI Case
Discussion in 'Other News' started by Baack, Sep 4, 2009.
  1. Baack
    Baack Road Train Member
    15,294
    10,174
    May 24, 2007
    Wisconsin
    http://www.newsnet5.com/health/20703731/detail.html
  3. Drachen
    Drachen Heavy Load Member
    721
    1,766
    Jan 29, 2008
    Indiana
    how'd they get a warrant if the breathalyzer said it was under .08?
  4. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    the road less travelled
    Supposedly, if you have been drinking, and blow less than .08, by the time they draw blood, it will be over .08, but only if it was close to begin with.
  5. dirtyoldman
    dirtyoldman Light Load Member
    264
    70
    Dec 30, 2007
    None of your business
    and only if there is undigested alcohol in your system.
    BS either way, breathalyzer is imho against the 5th amendment rights.
    K
  6. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    I agree, but the guy didn't refuse that test, if any shows on it the officer was able to use reasonable suspicion as grounds to get blood and urine tested. Another one of those slippery slope situations.
    As far as I'm concerned, knowing what we know from this, that cop should be inspecting used manure spreaders for charging the guy with anything after the tests showed the guy wasn't over the limit. I expect that the limit will be further reduced in years to come and that the right to do things like imbibe in private will disappear as well.
  7. Markk9
    Markk9 "On your mark"
    1,052
    229
    Nov 26, 2006
    Lehigh Valley, PA
    When you get a driver license you are signing a document that gives the state the right to check you for DUI. Driving is not a right.....................
    But, what this cop did is down right wrong. I hope cop and city lose a big sum of money.
    Mark
  8. leannamarie
    leannamarie "California Girl"
    Driving is a privilege, not a right. You agree to submit to testing when you get your driver's license. The guy should have submitted to a test. He failed to do so, so I have no problem with forced catheterization in that case.
  9. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    This is a gray area.
    The driver in this instance DID comply with the testing at the scene. It clearly showed he was not over the limit. The officer FAILED to show the reason for further testing. He did this by a gut feeling. Which should be noted was wrong.
    I do not condone that the driver did not want the further testing, but I also do see where the officer was wrong.
    Otherwise, look forward for more of this to happen. They could pull over a driver and give a breath test to them. It comes back negative, so the officer says, I think it is wrong. Let's go to the hospital for further testing. Guess who pays for the testing?
    No, I think he over stepped the boundary.
  10. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    I don't see anything grey about it. The guy was asked to submit to a breath analyzer, and did.
    The cop had reasonable suspicion to request it. But once it was passed, there was no grounds for further suspicion.
    Passing the test, the officer over stepped his authority by submitting the driver to additional unfounded and unwarranted test.
    Some may argue the badge gave the officer that authority. The court will decide who is right in this case.
    I do. We're not playing golf, the officer doesn't get a mulligan. The driver won that round. Not being a good sport, or simply just being an A hole of a bully, the officer abused his authority.
    Agreed......
  11. dirtyoldman
    264
    70
    Dec 30, 2007
    yes, BUT because the penalties are assessed in court, where penalties include jail, you are entitled to your constitutional rights. If they simply took your license then yes it would be a privilege.
    K
    ps stop it ith the huge font, you are not that important.
