Forced to move during 10 hour break
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Pickneytc, Aug 4, 2021.
  1. Pickneytc
    Pickneytc Bobtail Member
    6
    Aug 4, 2021
    Was on my 10 hour break then being asked by emergency personnel to move. Literally took 3 mins. Which of course reset my 10 consecutive hour break for a 14 hour restart. Do I have to restart the clock or can I pick up from where I left off? I am new to this and need help.
  3. flood
    flood Road Train Member
    4,167
    4,045
    Dec 25, 2010
    IF your log has pc then that is what you should have used...
    You may be able to do a split depending on how long you were parked before the move
    Tb0n3 and Dieselboss Thank this.
  4. skallagrime
    skallagrime Road Train Member
    3,850
    9,923
    Apr 10, 2012
    Indiana
    Just plop on sleeper berth, as long as it was between 2/3 hrs or 7/8 going back to sleeper for the rest of the time, itll only have stolen 3 min from your 14, if it was at say the 5 hr mark, youll have to take another 7 hrs
    alds and flood Thank this.
  5. Pickneytc
    6
    Aug 4, 2021
    Let’s say I started the break at 10:30 and was told to move at 3:30. Do I turn on the sleeper from 10:30 to 3:30 back on? Thank you for helping
  6. Pickneytc
    6
    Aug 4, 2021
    Log dose not have PC on there they have a annotation comment section. I was parked for a little over 5 hours. Thank you for helping me
  7. flood
    4,167
    4,045
    Dec 25, 2010
    The 1st 5hrs (sleeper or off duty doesn't matter) count as the 3hr part of a 3/7 split.... you will need to log from AFTER the move 7hrs in the sleeper to finish the split
    skallagrime Thanks this.
  8. skallagrime
    3,850
    9,923
    Apr 10, 2012
    Indiana
    Sleeper must be used for the longer 7+ hr break, so no need but i tend to log almost all off duty time when im with the truck as sleeper to eliminate the worry
    Snailexpress Thanks this.
  9. Pickneytc
    6
    Aug 4, 2021
    I will use this advice thank you. If I would driver after my initial 10 hour break was up. Instead of waiting 12 (5 hour then 7 hour split). Will they still consider it a violation.
  10. Pickneytc
    6
    Aug 4, 2021
    Do this create a 12 (5hour before the move plus the 7 hour after to complete the split) hour break instead of the initial 10
  11. flood
    4,167
    4,045
    Dec 25, 2010
    The MOVE forces you to do the split or take a full 10 after the move
    Dieselboss Thanks this.
