forward axle wheel seals leaks
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by catnwhopper, Feb 19, 2021.
  1. catnwhopper
    catnwhopper Bobtail Member
    39
    25
    Sep 9, 2012
    Both seals leaking! on the spicer forward axle
    power divider and cross locks working properly,
    dash light for power divider stuck on. Sorry I should have mentioned
    I haven't taken the wheels apart yet!
    just curious never had two seals on the same axle leak like that before.
    Be taking wheels off Monday!
  3. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    Check the vent for plugging.
  4. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Did you remove the old wear sleeve from the axle? What brand seal was installed?
    Most wheel seal issues are due to misinstallation of some type.
    catnwhopper Thanks this.
  5. AModelCat
    164,642
    Regardless I would check the vent. If both seals are brand new and just installed, I'd lean towards improper installation.
  6. ChuckMartel
    160
    94
    Jan 22, 2021
    And if the light is on in the dash at all times check the switch operation in the diff. Most likely the it’s stuck closed.
  7. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Always insist on Stemco seals..
  8. Isafarmboy
    Isafarmboy Road Train Member
    2,977
    32,424
    Jul 2, 2018
    Alberta
    Check air seal at power divider actuator. Its leaking past and pressurizing the whole rear end.
